Good old Inspiron 9100 CPU questions.
2,555 (0.38/day)
Illinois
Processor i7 2600k@4.6ghz
Motherboard MSI z68ma-ed55
Cooling Silentx Extreem 120mm
Memory 2x4gb XMS 7-8-7-20 1600
Video Card(s) HD6870
Storage 2x128gb Kingston Hyper-X (Raid0), 2x750gb RE3 (RAID1), 2x750gb RE3 (RAID1)
Display(s) Soyo 24", Gateway 22"
Case Fractal Design Arc Mini 6x120mm fans.
Power Supply Zalman 750w
Software Windows 7
I figure I'll hit up you guys about this one. I picked up an old Dell Inspiron 9100. I hear they run hot and some people swap in Northwood chips to keep it cooler.
Service tag is 8VYQT51. Here is Dell's system info on it.
http://support.dell.com/support/top.../details?~ck=ln&~tab=2&c=us&l=en&lnki=0&s=gen
"PRC,80546,3.0,1M,P4PD,800,D0" is listed as the CPU. 3ghz, 1mb, 800fsb D0 stepping. It's socket 478 I believe. Does anyone know which P4 this is? Prescott? Is it HT? What I'd like to know is, what CPUs will interchange in this laptop? Is it worth swapping in a Northwood to keep it cool? Maybe that would open up some overclocking headroom.
thanks.
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
Sup dude! Where you been?
Yep its a prescott and should have HT.
Northwoods don't run THAT much cooler, and you are halving the cache. I mean its a laptop, you cant overclock it and stuff so if it runs it runs :p.
2,555 (0.38/day)
Illinois
Software Windows 7
Hi pinchy!
I've been super busy. Turboing my Mazdas, building a 120v electric Yamaha cycle, fixing computers, and a dozen other forums to deal with. The usual. :D
Apperently the 9100 uses desktop components on the board like a 865PE chipset for example. Apperently it has a PLL that the fsb utilities can access. I bought it just to tinker around with anyways. To be honest. I bought it because it was $125 and has a subwoofer. :p I have other laptops that work fine.
I did get one of those Acer One minis. I love it.
