dabread
- Jun 30, 2011
- 4 (0.00/day)
System Name | Emachines Custom |
Processor | QuadCore AMD Phenom X4 9850 |
Motherboard | Gigabyte GA-MA785GM-US2H |
Cooling | Cooler master Hyper 212 plus |
Memory | 4GB ddr2 800 |
Video Card(s) | ATI Radeon HD 5830 (Cypress) |
Storage | Toshiba 160GB |
Display(s) | 1440*900 19inch |
Case | emachine et1161 case |
Audio Device(s) | 7.1 build-in |
Power Supply | 550W |
Software | Windows 7 64bit |
Benchmark Scores | 6 Windows experience index |
Hardware:
Mobo Gigabyte GA-MA785GM-US2H
CPU Type QuadCore AMD Phenom X4 9850
RAM 4gb ddr2 800
Video Adapter ATI Radeon HD 5830 (Cypress)
Software:
Window XP 32bit
Windows 7 64bit
Problem: When i install it it worked fine untill i turned off the computer.
1) There is no display after i turn off the computer then put in back on, if i restart the computer it work but when i turn it off, I hv to remove the card and put it back in and turn on/off the computer serveral times for it to read. Its like the Bios wont hold the GPU info. Other cards work fine, and i sometime put another card in then put the 5830 back and it works.
2) GPU idles at 60, its not overclocked but it seems amd overdrive is making it run at 400mhz gpu clock and 1000mhz all the time, so it dont idle. Where i sure online that its run lower idle.
however when i lower it down manually the graphics on the computer flickers ALOT.
Number 1 is the real problem. Any help??
RAM 4gb ddr2 800
Software:
Window XP 32bit
Windows 7 64bit
