- Aug 10, 2020
- 105 (0.06/day)
System Name | R5 3600 |
Processor | R5 3600 |
Motherboard | b450 mortar max |
Cooling | Deepcool Gammaxx L240 Aio |
Memory | Corsair Vengeance LPX 32GB (2x8GB) DDR4 3200MHz cl16 |
Video Card(s) | RX 6600 XT 8GB MECHx2 OCV1 |
Storage | C drive samsung 980 evo m.2 storage drive Crucial_CT275MX300SSD1 500gig Samsung SSD 860 QVO 1TB |
Display(s) | aoc 27g2 |
Case | SilverStone FARA R1 |
Audio Device(s) | sony ear buds |
Power Supply | SilverStone ET550-B 550W 80+ Bronze Essential |
Mouse | razer basilisk x hyperspeed |
Keyboard | Logitech G PRO X Mechanical Gaming Keyboard |
Software | windows 10 enterprise |
hi so im using a 6600xt and one of the fans stuffed up on it so i took fans out of a gtx 1050ti that look identical to the fans in the 6600xt
i know the fans from the 1050ti work fine and when i put them in the 6600xt . thet dont turn on unless i unplug and replug then in to the fan header on the gpu while the system is on but if i power the system off and back on the gpu fans dont turn on .
i dont have zero rpm set to on and even if i manualy tell the fans to turn on they still dont unless i unplug and replug then in to the fan header on the gpu while the system is on
i find this strange and not sure if i should buy fans specific to the 6600xt or if the fan header is broken
anyone had a issue like this before im up to date with all drivers and i know no program is preventing fans from starting
