psymushroom
- Jun 12, 2012
- 5 (0.00/day)
I'm having some serious problems with my laptop.Recently a friend gave me an Lg Flatron w2243s so i desided to connect it. I use it as default screen, not dual or expand, at 1920 x 1080 (its recommended by windows settings)
My problem is that everytime i open the laptop, after 2 hours of working the screen crash and i can't do anything(the mouse is moving, the sounds still sounds but the screen is showing the same thing)the ONLY thing i can do to save my progress of everything i do, is to press ctrl+alt+delete and then Change User and Log In again, save everything and then a reboot because the system doesn't run properly..It happens every 2-3 hours.
At most of the times the crash happens
1) If i'm on a web browser (firefox or chrome) and the site i'm watching contains adds with sort videos and i scroling up and down with mouse quickly.
2) When i use visualizer for music in media players
3) When i do many things together and have 4-8 apps open(the crash happens when something is moving on the screen)
4) and finally when i don't do anything at all and it just wait!! (about 10-15 minutes then crash..)
Until now i NEVER get this crash while playing any video of any size or time(usually i use VLC and .mkv containers with hd video) and while working on windows explorer.
Also i NEVER had any known problems before with graphics or something else.
The reason that i believe the temp is the problem is simple... i use 2 softwares to check the temp sensors, the one is from this site! My laptop temp is all the time about 68c - 74c and reach 82c so easily.
I use a cooler stand with a 20cm fan but its a crap!!! I think all those coolers in the market for the laptops are complete waste of money since all the laptops is full covered with plastic all around!
So what do you think i sould do to fix the thngs?!!
Vaio specs
sony vaio VGN-NR11Z/S 4,5 years old
CPU Intel Core 2 Duo T7250 2.00GHz
GPU Mobile Intel GMA X3100
ram 4GB DDR2 (667MHz)
HDD 500GB
screen of 15.4" WXGA (1280 x 800)
win 7 ultimate
Thanks in advance!!
Vaio specs
HDD 500GB
win 7 ultimate
Thanks in advance!!
