Gpu / psu pcle pin
But since my 650W Be Quiet Bronze PSU is supposed to have PCIe 6+2, can I connect a 7900gre that has 8-PIN PCIe?
How many pins does 6+2 = ???? yup 8 it's designed as a multi plug type so it can either be 6pin or 8pin (if you use the extra 2 pins attached)
you can use the 6+2 connector to plug into your RX7900GRE's 8 pin PCIe Power
