mynameislong
- Mar 12, 2017
- 6 (0.00/day)
Hi all, first time posting here. I have a Razer Blade 14 (970m with i7 4720HQ) which I've owned for over a year but recently I experienced a new problem I've never encountered before.
While playing League of Legends, I noticed my FPS (which is normally capped at 60 without ever dropping), started dropping to 30 for a few seconds then coming back up to 60. It would drop to 30 as if I had unplugged the charger where it stays at exactly 30. This is the first time I have ever encountered this situation. I changed screen brightness to 5% when unplugged to see if there was intermittent "unplugging" of the charger, and sure enough when the FPS dropped the screen would also go dark.
I went to look at MSI afterburner to see if anything funny was going on, but my GPU usage and temperature were both at their typical values (in the 60-70 degree range and around 60% GPU usage - no where near max where I get around 90 degrees with 100% GPU usage on AAA titles). What I did notice was that the "GPU power limit" would spike to the value "1", last a few seconds then return to "0", coinciding with the FPS drop. I haven't overclocked or changed the voltage settings at all either. I then ran the Heaven benchmark and also experienced FPS drops unlike my previous Heaven benchmarks which didn't have this problem. I can't think of anything that has changed to cause this so suddenly.
Although initially seeming like a problem due solely to the battery status intermittently changing from plugged to unplugged, what concerns me the most is that the FPS drops were more frequent the more my GPU was under load. In LoL it would happen once every 10 minutes, in Chivalry it's once every 10 seconds, in Heaven benchmark it's virtually constant. I have emailed Razer and they suggested reinstalling the battery driver although that didn't seem to fix it, and am waiting for a friend to pop by and use their charger to see if it's my charger. Does anyone have any suggestions/advice? Thanks for reading this far!
