GPU strip blinking,Trixx software not working properly,fan health fail...
Popikaify
1 (0.07/day)
Im having issue with my GPU rgb bar (7900Gre Sapphire Nitro+),it worked for few months perfectly,then all of sudden after accidentaly installed beta signalrgb build ,gpu rgb bar started to blink,i can still change the color but every few seconds it starts blinking.I also noticed that im no longer able to change bios version in sapphire trixx software,change color and mode,and fans health always fail the test even though they're working during gaming,temps are fine,even during the test i can hear them ramping up very loud.
In the last 2 months tried to cmos reset,bios reset,updated bios to a newer versions 2 times,reinstalled msi center/mystic light and sapphire trixx,reinstalled windows 11 two times,swapped bios on card,replugged cables in hope they were loose,and of course keep everything updated windows/drivers ,is there anything else i could try ?
It looks similiar to this,but not as strong :
Remove windows completely
