- Nov 2, 2020
- 1,737 (1.05/day)
- Tel Fyr
System Name | 1️Purple Haze 2️Vacuum Box |
Processor | 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3 |
Motherboard | 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H |
Cooling | 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans |
Memory | 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP) |
Video Card(s) | 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2 |
Storage | 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB |
Display(s) | TCL C805 50" 2160p 144Hz VA miniLED, Mi 27" 1440p 165Hz IPS, AOC 24G2U 1080p 144Hz IPS |
Case | 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L |
Audio Device(s) | Audient iD14 MKII, Adam Audio T8Vs, Bloody M550, HiFiMan HE400se, Tascam TM-80, DS4 v2 |
Power Supply | 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans) |
Mouse | Logitech G305, Bloody A91, Amazon basics, Logitech M187 |
Keyboard | Redragon K530, Bloody B930, Epomaker TH80 SE, BTC 9110 |
Software | W10LTSC 21H2, PBO2, FF, MusicBee, mpv, ImageGlass, OpenRGB, FanControl, Greenshot, DS4Win, Signal |
Decided to make a thread to share information from my own experience, and to encourage others as well, so that one day we could have one place to go for information about thermal pads thickness for specific GPU models. Searching through the internet for a bit of an info on this topic can be tiresome and not many people like to spend their time hiking through the toxic wastelands of Reddit.
So if you are a brave adventurer who decided to take your precious GPU apart to repaste and change the factory pads, skillful enough to use a caliper, please share your findings!
We all know how disturbing it is to teardown a GPU and then figure you don't have the right pads for the job, and those destroyed factory pads mostly on mosfets and VRAM might start crawling into your dreams. So let's try to maker it easier.
I'll make an example with my Asrock 6900XT OC Formula:
Purple ones 2mm;
Green 1,5mm.
It's all 3mm pads between the PCB and the backplate. The ones marked in green aren't there from the factory, but I still added them.
Before adding the pads, one should observe position of the components cooled with the pads vs. the cooler by attaching the cooler on the bare PCB and looking from the sides. There is a slight offset regarding the MOSFETs on both sides for this particular GPU.
Coming up next: Sapphire 5700XT Nitro+ in a day or two, and Aorus GTX 1060 when I finally get missing parts for another PC I don't really need.
Purple ones 2mm;
Green 1,5mm.
