- Sep 7, 2018
- 32 (0.01/day)
Hello people, I will be quick and clear. I need to change the termal paste on my graphics card and I want you to tell me which of the ones I will list will have the same performance as the stock paste.
These are the only pastes available to me, at my lication. I will physically go to a store and buy paste, yeah.
https://www.hgshop.hr/proizvod/termalna-pasta-arctic-cooling-mx-4-4g/182147
https://www.chipoteka.hr/artikl/139...ovodljiva-ag-diamond-ag-termopasty-8072000361
https://www.chipoteka.hr/artikl/139...ovodljiva-ag-extreme-ag-termopasty-8072000355
https://www.chipoteka.hr/artikl/139...ljiva-ag-silver-brushag-termopasty-8072000357
https://www.chipoteka.hr/artikl/139...movodljiva-ag-silver-ag-termopasty-8072000358
These are my only options for now.
Also, please tell me which of these screwdrivers will fit perfectly into the screws of the graphics card pcb, AND WHAT SIZE, in mm, please. Up to 36kn.
https://www.chipoteka.hr/search?q=Odvijač+križni
My graphics card is https://www.techpowerup.com/gpudb/b2153/gainward-gtx-760
IMPORTANT NOTES
1.) My cards (both) have a peak of 1097 Mhz @ 80-81 celsius, and 100% usage. I can let them run like that for months without end. (If you don't believe me, get one and try it.)
2.) I need to change the paste on the first card because it has started rapidly dropping clock to 980 Mhz @ 81 C. That is horrible because that has never happened in the last 2 years.
3.) HOW do I put back the screws with springs!? Do I need to press hard or how?
IMPORTANT NOTES
