GPU Usage drops to 0%
Baner
5 (0.00/day)
After 20 min of gaming every 1 minute (IMAGE INCLUDED) gpu usage drops to 0% for 1 sec.VID drops to 0. Fps drops from 50 to 1fps. Gpu clock drops from 1137 to 1072 MHz. CPU usage drops from 40% to 15%. Voltage seems ok. It appears for 1 sec and after that it's working fine for ~1 min.
Played Outlast 2 everything was fine. Games with less requirements as cs go are working properly. FPS drops in Hitman, Sniper Ghost warrior 3, Mass Effect Andromeda.
ITS NOT TEMP ISSUE. PC is stable (benchmarking for over 30 mins). Drivers up to date.
Specs : (DxDiag INCLUDED)
GTX 760 by evega
Intel 2600k
RAM 8 GB 1333
PSU Modecom MC 620 carbon 620w
Asustek p8z68-v vx
What I tried:
Underclocking, undervolatege/overvoltage, forcing fan to 100%
Update/reinstall drivers
Opening case (PCI slot, cables, dust etc. check)
BIOS (fixed voltage (tried auto also), C1E is disabled, turbomode disabled)
Diagnostics - mdsched (ram), dxdiag, viruses
Closing all background applications
To see monitor stats press "Copy image address" there you can see things or press "Open in new tab"
  • DxDiag.txt
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
open an elevated CMD prompt, and run sfc/scannow , see if it finds any issues with your OS
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
I wouldn't trust that PSU to hold certain loads.
Baner
5 (0.00/day)
I can try to use my ancient Asus Exda40rc0 (400w) to drive my gpu, but it has only one 1x 6 pin. I could use one 6pin from old and new psu, but I think that is unsafe. Should I try?
Toothless
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
No. Get a real PSU.
23,888 (6.16/day)
^ listen to this man, before things crash and burn
2,381 (0.49/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
nv control panel -> prefer max performance
windows -> control panel -> power -> high perf -> min cpu state -> 100%
then report back
23,888 (6.16/day)
If the above will give you bluescreens, thats another confirmation that this PSU needs replacing, because the above settings will definitely increase power draw at any given time.
Other than that I doubt it'll do much.
2,381 (0.49/day)
System Name msdos
Processor 8086
Cooling passive
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Mouse serial
Keyboard yes
It stops some games from having mysterious cyclical performance drops.
Baner
5 (0.00/day)
then report back
It was on 100%. I replaced pci-e slot and fps droped from 40 fps (medium settings) to 17 fps (medium settings). I tried low settings and it became stable. But Ghost warrior still not stable even on 800x600. Tried the surge(max), get even (max), prey (medium) these were stable. As i figured out lack of ram is causing drops, I lowered textures and raised other setting to med-high and I got normal fps and it was stable. Not sure why GW3 is not stable, most probably of open-world and bad render system.
44,278 (6.80/day)
How old is that PSU?
23,888 (6.16/day)
Image quality should not have an affect on application stability unless you don't meet hardware requirements and a GTX 760 + 2600k do meet requirements for all of todays' games. If you push the hardware with higher settings the game should simply run at lower FPS, and that is all. If a GPU is short on VRAM yes it can stutter, but 0% usage is not stutter, its a 'hang' and generally indicates either an issue with accessing storage, RAM, and more often than not: PSU.
The least you can do is check the +12V line voltage under load, and see if it exceeds ATX spec.
9,801 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
If you are talking about the lack of video RAM , then yes that can cause huge drops in performance , it looks like you're clearly running out of VRAM from the picture in your first post so that's most likely the cause of you problem . You have the 2GB 760 ?
PSU still could be not that great though.
You are not entirely correct , running out of VRAM can cause pretty bad stuttering and can also definitely cause GPU usage to drop to 0%. As in with every piece of software when you run out of memory and have to copy/read from somewhere else that can result in a complete halt in execution. GPU architecture relies by design on constant flow of "work".
2,972 (0.56/day)
System Name Old Fart / Young Dude
Processor 2500K / 6600K
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / CM Hyper 212 EVO
Memory 16 GB Kingston HyperX / 16 GB G.Skill Ripjaws X
Video Card(s) Gigabyte GTX 1050 Ti / INNO3D RTX 2060
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / LG UHD 43" TV
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/ FiiO D03K/ JBL LSR 305
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100 / Rival 110
Keyboard Sidewinder/ Steelseries Apex 150
Software Windows 10 / Windows 10 Pro
In Hitman you can set a limit to VRAM so that it will use only what's available. Try that and see if you still get the FPS drop.
12,062 (2.53/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Your GPU is hitting its VRAM cap. When a GPU runs out of VRAM it falls over to RAM. Unfortunately you only have 8GB of RAM, Windows probs uses about 2-3GB and the game itself will probably be eating another 3-4GB for general processing. That leaves you with 1GB free, which I imagine is in short supply if you have any other programs running. So when your GPU runs out of VRAM, it starts dumping things into your slower system RAM. When your system RAM runs out it falls over to Page File, which runs from the C:\ drive (aka your HDD/SSD) which has even slower access speeds. When your computer starts resorting to page file on the local drive, framerates will absolutely crash into oblivion.
I'd suggest more RAM, and lowering your texture settings so you don't saturate your entire GPUs VRAM pool.
Your PSU is also jank, made by the SAMA OEM (nasty cheap Chinese manufacturer).
EDIT: Here's how much system RAM MEA uses at 1080p:
9,801 (3.23/day)
Case Phanteks NV7
Though I agree with most of what you wrote , I think adding more RAM it's not going to do much. The issues is that even if you have plenty RAM just the act of writing and reading to system memory and then to VRAM repeatedly is a huge performance wrecking action by itself.
If his issue is indeed VRAM , then the most practical solution is getting a card that has more.
12,062 (2.53/day)
Gypsyland, UK
Processor i7 7700HQ
Power Supply 230W
Pretty much yeah, depends if he has the funds to do such a thing - judging by the choice of PSU I'd guess not.
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
No. Get a real PSU.
His GPU uses 155 watts max
His CPU uses 240 watts max
I doubt his PSU is the issue unless it is malfunctioning.
I agree with Vram running out and then bog down when harddrive is transferring the needed new Vram ....stuttering is the outcome.
44,278 (6.80/day)
And he is gone.
9,801 (3.23/day)
Case Phanteks NV7
Baner
5 (0.00/day)
Its 6 years old.
You have the 2GB 760?PSU still could be not that great though.
Yes, it's 2gb. Yes, i know its not well know manufacturer and they could use bad internals, but its working for my current system.
As i mentioned before i lowered textures and now it's stable.
It also could be VRAM, but it's less likely.
As i calculated my system should require ~360w. Even if my psu can provide only 65% (422 of 620) of power it's should be enough.
Yes, you discribed this process correctly (relying on my knowledge of how it works). As i said earlier it's most probably lack of DRAM is causing drops it just chokes on amound of data. I also tried to boost pci-e bandwidth, which speeds up the flow of data, but I stoped at 105 (if i set more it's not working properly) and 105 was is not enough.
Yes, I will not add 4gb of ram or buy new gpu. Most likely i will wait for Ice lake or die shrink to 6 nm (if we consider a ~35% dicrease every macroarchitecture) 1st optimisation also known as "tock". And build completely new system for another 5-7 years.
And he is gone.
As i mentioned before I lowered textures and now it seems stable, for now at least.
Thank you all for responses.
44,278 (6.80/day)
The least you can try is replace the tim on the gpu die and thermal pads, dust it thoroughly and replace the psu with a reputable model.
Otherwise replace gpu and psu...
2,381 (0.49/day)
System Name msdos
Processor 8086
Cooling passive
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Mouse serial
Keyboard yes
The DDR3-1333 hurts for sure, especially if it's a single stick.
9,801 (3.23/day)
Case Phanteks NV7
This has been demonstrated over and over (for this platform at least) : RAM speed doesn't affect performance in any significant way. His issue is lack of VRAM most likely.
