GPU-Z and Afterburner?
2,640 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01 w/Alphacool Apex RAM X4 Water Cooler and Core DDR5-RAM Module
Video Card(s) MSI Suprim SOC w/Alphacool Core Geforce RTX 5080 Suprim + Vanguard with Backplate
Storage Samsung 990 PRO 1TB M.2
Display(s) MSI 321URX
Case Custom open frame chassis
Audio Device(s) CREATIVE AE-9/Nakamichi Shockwafe Ultra 9.2.4
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Does running GPU-Z and MSI Afterburner concurrently cause problems?
Someone on another forum said there was a KNOWN issue with the two, but I cannot seem to find a reference to it.
Perhaps someone knows something?
Thanks
I have never once had an issue running Afterburner, which runs all the time, and GPU-Z.
there should be no issues, everything else is a bug.
if you have problems report them here and i'll get them fixed
I have never had problems with both applications running simultaneously either, but then I am not always upon the latest news and thought I would ask.
I believe the person is talking out the wrong orifice.
I am not sure which is at fault, but running afterburner and gpu-z with voltage monitoring enabled in BOTH will cause certain 5000 series ATI cards to bump to their highest programmable voltage - 1.65 on the 5870. This also happens with Everest/Aida64 1.20/1.50 and gpu-z both running at the same time. I have experienced this myself and have read of others warning of it on guru3d. I would think this is more the fault of the card, but still 1.65 is not a voltage you want your card running at.
On quick search here are some other post referencing it:
http://forums.overclockers.com.au/showthread.php?t=885838
http://forums.extremeoverclocking.com/showthread.php?p=3570275
http://www.overclock.net/ati/701765-weird-voltage-issue-5870-a.html
