Necrophagist98
- Apr 10, 2022
- 4 (0.00/day)
Hello, correct me if I'm wrong, but only the newest GDDR6X graphics cards have a VRAM thermal sensor, right? It shows up in hwinfo for people who have those GPUs. I have a 2080 and hwinfo only tells me my hotspot and my core temp. However, GPU-Z and HWmonitor shows the same identical reading for both my memory and hotspot. My hotspot is 10 degrees hotter when idle and 15 degrees hotter than my core temp under heavy load, which by GPU-Z's logic means that my VRAM is also 15 degrees above my core temp under load. How can it show me my memory temperature when my GPU doesn't have a VRAM sensor? I hope it's a fake reading or something. I've seen many people's readings and every 2xxx series card I've seen has the same readings as me, in that the memory temperature and the hotspot temperature are always identical. However, every 3xxx series card I've seen has different readings for the memory and for the hotspot. Is it possible that GPU-Z is simply copying my hotspot temperature and that it's showing my real memory temp? I've looked online but have come up with nothing. I'm kinda bummed since I'm getting worried that my memory might be throttling without me knowing, that's why I'm hoping it's a fake reading. Thank you!
