GPU-Z Help!
yoh012
13 (0.00/day)
System Name Microsoft Windows XP Servie Pack 3
Processor Intel(R) Petium(R) 4 CPU 2.40GHz
Memory 1gb
Video Card(s) Nvidia Geforce FX 5200 256mb
im newbie here but i'll just ask some questions that are bothering me.
i have nvidia geforce fx 5200 256mb
GPU-Z says
bios (Unknown)
shaders (Unified)
memory size (0mb)
would any one please explain to me about this?
GeForce FX are kinda unsupported because they are just too old. GeForce 6 are the first cards that GPU-Z is really tested on.
i see by the way thank you very much for the info
You could start by updating your video driver. http://www.nvidia.com/object/winxp_175.19_whql.html
sir i tried to intall that driver but i have an error everytime i update the driver.
this is the error i usually get:
"The Nvidia setup program could not locate any drivers that are compatible with your current hardware. Setup will now exit."
now the current driver i have is 91.31
This is just an observation... however, I wonder if that card is a 5200 FX, as it shows (in the screen shot you posted: http://www.techpowerup.com/forums/attachment.php?attachmentid=51366&d=1371014345) as a NV18 which was in the 4XXX series.
The 5200 series card was the NV34, IIRC. Now, I could be wrong, but that may be why the latest driver you can use(stock - without modifying) is the 9X.XX drivers, as the 175.XX driver does not support the 4XXX series.
Like I said, "Just an Observation".
EDIT: @OP> Here is some reference on the chipsets/gpu: GPU Review
i have also observed that what could be the solution to my problem?
What exact OS are you using?
