GPU-Z HWmonitor temp differences
2,417 (0.39/day)
Toronto, Ont
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
Which one should I believe? I mean, if the GPU-Z temps are right, I feel ok. But if the HWmonitor temps are right, I don't feel ok.
What does CCC show as your temps?
I have HWMonitor on my drive; however, I might look at it, but I don't trust just one.
If, I wanna know the real temps, I break out the multi-meter thermal probe or use the laser thermometer.
Look at Value and Min temps for your CPU - 8 degrees centigrade... you have one cold room there.:rolleyes:
Your local temps seem more around 21C than 8C. Just saying, sorta hard to get those temps on air, unless you have lowered your ambient temps..
Run a few other apps, if, you have no other options to verify and average it out.
Another one I like is HWInfo 32 or 64 bit.
I think I would lean more towards GPUz, too. Just my opinion.:)
EDIT:
GPU-Z. HWMonitor is showing your the same temp as "GPU Temp #1" on GPU-Z. You're comparing two different sensors on the GPU.
Good eyeballing there, erocker, I musta been dozing... I did not even see that 'till you posted.:toast:
Liano chips do this. Others have reported it as well.
That Hwinfo program is great. Thanks!
So it appears HWmonitor is right after all?
