gpu-z weird readings
Mavellion
3 (0.00/day)
Hello i have a gtx 1080ti on an asus x99 gaming motherboard with a 6850k cpu and my texture and pixel fill rate are changing and fluctuating up and down on the graphics card tab can anyone tell me why this is happening. is it just a bug?
These cards have variable clock speeds , therefore pixel fill rate and texture fill rate vary as well.
they are tied to the clocks displayed on the bottom of the first tab. can you confirm that those are changing, too? what's the range of values that you see?
Because GPU-Z shows base clock readings not the boost clocks, if you want the boost clocks, click that little tick next to the PCI-E Gen version and link speed.
So it goes in steps from 0 to 1703 and then slowly goes down again or is it more random?
after fidling around i think it seems to be a bug because if i leave the program open for a min it stops doing it and shows the correct numbers.
