I'm using a Powercolor 9600XT graphic card which defaults at 500/338, and also the ATi Control Panel, as I heard the Control Centre is a terrible memory hog. AFAIK, I'm using the latest drivers....
Anyway, on my Control Panel, there is no tab for the overdrive. I distinctly remember seeing it there before.....but now, there's no tab. According to the documentation that comes with my card, the function is there.
Should I use overdrive if I'm oc-ing my card? What are the limits I should respect for the card if I'm using the default hsf?
Also, while running 3dmark 03, I encountered some problems. I was running 3d Mark 03 just then, when halfway into all the tests, there was a error saying "atidvag display driver crashed or something like this", and I had to reboot.
What are the possible causes? I oc-ed the card too high? I tried running 3dmark 03 using my default card settings, and no error happened. Any idea why?
