Graphics card dying while in game, VGA turns light on
snipermunro
4 (0.00/day)
United States
Whenever I join a game in rainbow six or bf2 for example my screen goes black while my pc is still running, the VGA light on my motherboard then turns on and I have to shut down my computer to turn it back on.
I have tried re-seating my gpu and nothing happened, any help would be much appreciated.
Specs:
Msi B350 pc mate
Ryzen 1500x
Gigabyte 2070
32 gb 3200mhz ram
Corsair CX 750 w
Windows 10 64 bit.
Thanks again
-Andrew
Specs:
Msi B350 pc mate
Ryzen 1500x
Gigabyte 2070
32 gb 3200mhz ram
Corsair CX 750 w
Windows 10 64 bit.
Thanks again
-Andrew
Card or powersupply. Leaning towards card.
Do you have spare parts?
Overclocked CPU and/or GPU?
I do not have any spare parts, im trying the flash currently
Flash? Why? That's usually a bad idea unless the manufacturer tells you to do so.
Need info before you just flash your gpu.
How long have you had the card fore?
little less than a year
What should I do then?
RMA the card get away from the Corsair CX powersupply line and get a corsair rm, evga gold or seasonic gold.
RMx or RMi, the basic RM has low quality capacitors.
