graphics card randomly spikes to 100% usage then crashes
6 (0.00/day)
Processor AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor
Motherboard Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard
Cooling stock wraith cooler
Memory G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory
Video Card(s) Gigabyte GeForce RTX 2070 8 GB WINDFORCE 2X Video Card
Storage ADATA SU635 480 GB 2.5" Solid State Drive / Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal H
Display(s) Sceptre 24" Curved 75Hz Gaming / i also have some random dell monitor from my dads workplace
Case Fractal Design Focus G ATX Mid Tower Case
Power Supply EVGA GD (2019) 700 W 80+ Gold Certified ATX Power Supply
Mouse some 10$ mouse from wall mart
Keyboard etrobot mechanical gaming blue
so i built my new PC in January it was a 1660ti with a ryzen 5 3600. worked well for the first week but ever since then my GPU will randomly will hit 100% usage and crash my displays plus whatever programs i was running. it takes about 5 secs or so for the displays to turn back on. i originally thought i just had a faulty graphics card so i purchased a new 2070 as well as a ryzen 7 3700x and the problem persists. i have a 700 watt evga power supply, a b550 mother board, 16 gigs of ram at 3600mhz. all of my drivers are up to date and I have disabled any type of overclocking by selecting load optimized defaults in my bios. any ideas?
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Try running your memory at defaults not Xmp.
14,546 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Run a Malwarebytes scan.
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
You changed mobo, cpu and gpu. Psu and ram are the same? So it's one of the two.
345 (0.11/day)
Binghamton, NY
System Name The Final Straw - Part II
Processor Ryzen 5 4500
Motherboard ASRock B550 Phantom Gaming 4/ac
Cooling Arctic Liquid Freezer II 120
Memory G.Skill 16GB DDR4 3200 F4-3200C16D-16GVKB
Video Card(s) EVGA GTX 1660 Super SC Ultra 6GB GDDR6
Storage Crucial 1TB P3 NVMe + WD 2TB Black SN850X NVME + PNY 2TB CS900 SATA
Display(s) Acer VG270U P 2k
Case Fractal Design Meshify C
Audio Device(s) HDMI / SPDIF
Power Supply ASRock Challenger CL-850G
Mouse Logitech M510
Keyboard Logitech K270
VR HMD Why?
Software Windows 10 / 11
Benchmark Scores Currently N/A
Recommend doing a fresh install of your current O/S and drivers onto a different drive and then test without the PC being online.
6 (0.00/day)
the power supply is new aswell i had a 550 but i upgraded when i got the 2070/ryzen 7 3700x
6,270 (0.89/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Did you scan
Did you scan with malwarebytes to see if you have a miner that got installed unwantingly as Caring1 recommended? Also what error is in system logs when the crash happened? look in System and apps section of logs.
6 (0.00/day)
Ok so new problem I went into the bios and forced my ram to 3600 because I seen it was running at 2133 and now my system won't boot thishappend just now, is there a way I can just completely wipe and start anew with my pc
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
We could do with you filling out your system specs, what type, speed and timings are your ram's.
If you have the motherboard manual look up clearing CMOS in it, that or remove power leads and then open the pc up and remove the coin battery for ten minutes, refit the right way up.
6 (0.00/day)
6,431 (2.85/day)
Poland
Pro tip:
Throwing money at the problem isn't always the best solution.
My bet is on memory timings, VDDP, VDDG issues, etc.
6 (0.00/day)
alright were back i cleared the cmos and i got here running again, and i have also set everything in my bios to defaults
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
As a starting point your set, run it a bit see if the crash issues are resolved then move forward with increasing memory performance, over clocking the CPU is near pointless.
But do let us know if it's ok please.
6,431 (2.85/day)
Poland
Typhoon burner + Dram calculator. Adjust your timings and voltages, validate stability with Memtest64 or something similar. If you need help, ask here, somebody will explain the process to you.
Fill in your specs here:
Detailed systems specs, not just "B550 motherboard", provide brand and model. Same with ram, Gskill 3600 16gb doesn't say much, same as "2070" or "700W EVGA psu". Click on "System Specs" below my account on the left side or @theoneandonlymrk account and you will get idea what sort of info should be included.
988 (0.19/day)
Processor 10400
Video Card(s) 1650 Super
Case Coolermaster Ammo 533
Mouse G403
Keyboard Sidewinder x4
It worked fine for a week. Did you change something after a week? How often does this happen?
I agree with Paganstomp. A fresh windows install is a surefire way of determining if it's a software or hardware issue. Really, you should have done that before buying more gear.
2,970 (0.80/day)
Long Island
1. Did you follow the recommended procedure of formatting the boot drive and doing a refresh install of Windows ?
2. If not, did you at least uninstall all hardware drivers for the items being taken out, rebooted, shut down, remove the old hardware .... then install the new hatdware, set BIOS to defauilts, intsall the drivers for the new hardware ?
If not problems are to be expected, now that they are here, I wouldn't chance Option 2, Id do a fresh install.
Dux
511 (0.16/day)
Hmmm. Something like that from title happens to my pen*s. Spikes to 100% usage, and then crashes.
I'll let myself out.
6 (0.00/day)
thats the plan if nothing else helps
after running the scan there were a few problems found but after using the fix like the program said nothing seems to have changed
so sadly the issue persists could you explain to me where i can start with increasing my memory performance
do you mean when i first installed all my components back in January because i haven't done a windows install since the original one.
yeah that would have been the smart thing to do but i plan on doing that if none of the other fixes people suggest work for me
i have filled out the specs list : )
11,880 (2.15/day)
Manchester uk
VR HMD Oculus rift
I would get it working first, you would just compound your issues , might well be worth a fresh install if the Is drive is a carry over.
2,715 (0.56/day)
System Name MSI GP76
Processor intel i7 11800h
Cooling 2 laptop fans
Memory 32gb of 3000mhz DDR4
Video Card(s) Nvidia 3070
Mouse Logitech m705
Keyboard laptop keyboard
Usually happens to people that see other people of the same sex.
ar0m
12 (0.01/day)
@clinto I have the same memory, and the same GPU. I am also experiencing this problem. Usually, I am able to get into task manager and see that the GPU 3D view spikes up to 100% and just stays there. I can't open or close any applications, and I must hard restart. Have you found a solution to this problem? I've been beating myself up over it for about a month. Thank you!
1 (0.00/day)
System Name Windows 10 Pro
Processor AMD RYZEN 5 2600 (3.4GHz Up to 3.9GHz, AM4, 6 Cores 12 Threads)
Motherboard MSI B450 Tomahawk Max
Memory RAM G.SKILL RIPJAWS V 16GB (2x8GB) DDR4 3000MHz
Video Card(s) MSI GTX 1660 Ti 6GB Ventus XS OC
Storage SSD Samsung NVMe PM981 M.2 PCIe 256GB
Power Supply Cooler Master MWE 550 BRONZE V2
I make an account just to say I have the same problem as you.
It was 5 months ago, the problem occured, so I tried serveral things:
- first I thought it was the game itself caused the problem so I tried to optimize it, but
- update/roll back/clean install with DDU the graphic driver - no help
- clean install windows (wipe out the SSD drive completely and install) - no help
- turn of X-AMP - no help
I had done everything in my narrowed knowledge and power so I brought my PC to the store (where bought it by the end of 2019). The technicians there saw the problem, took every part to check each of them for nearly a week - found nothing. In the end they put everything together, updated the BIOS, and the problem is gone. I've been using it for ~5 months now and it's coming back last night, I actually have no idea why and how to deal with this again.
If you find anything please let me know, thank you.
ar0m
12 (0.01/day)
Hey ArrowXIII, take a look at this thread: https://www.techpowerup.com/forums/threads/rtx-2070-spikes-up-to-100-usage-and-freezes.274797/
