I have a AOC 34" gaming cu34g2xp from Dec 2024. Bought in march 2024. Pretty new. I use it to my vintage workstation Dell T3500 precision. The graphic card is a old one. Gigabyte Nvidia geforce GTX 660 windforce. The cables are the ones who followed with the AOC screen.
NVIDIA GK106, 1098 MHz, 960 Cores, 80 TMUs, 24 ROPs, 2048 MB GDDR5, 1502 MHz, 192 bit
www.techpowerup.com
aoc.com
I use Windows 8.1 on that. It seems complicated to install 10 when it is missing the UEFI bios that requires. But i have learned that you create a Usb with legacy boot.
Visa information
Skärmstorlek (tum)
34
Skärmstorlek (cm)
86.4
Krökningsradie
1500R
Panelbehandling
Antiglare (AG)
Pixelavstånd (mm)
0.23175
Punkter per tum
109.7
Panelupplösning
3440x1440
Bildförhållande
21:9
Paneltyp
VA
Bakgrundsbelysningstyp
WLED
Max Uppdateringshastighet
180 Hz
Svarstid GtG
1 ms
Svarstid MPRT
1 ms
Statiskt kontrastförhållande
4000:1
Dynamiskt kontrastförhållande
80M:1
Betraktningsvinkel (CR10)
178/178
Displayfärger
1,07 miljarder
Brightness in nits
430 cd/m2
OD Response (typical)
1 ms GtG
Panel Haze Value
25%
Support 1:1 function
Videofunktioner
Synkroniseringsteknik (VRR)
Adaptive Sync
Digital signalfrekvens vertikal
48-100HZ(HDMI), 48-144HZ(DP)
Digital signalfrekvens horisontell
30k-160kHZ(HDMI), 30k-220kHZ(DP)
HDR (High Dynamic Range)
VESA Certified DisplayHDR™ 400
Blue Light-teknik
Svagt blått ljus
Multiview (PbP, PiP)
PiP+PbP
Färgutrymme (sRGB) CIE 1931%
126.5
Färgutrymme (DCI-P3) CIE 1976%
95.1
Färgutrymme (Adobe RGB) CIE 1976%
91.4
Flimmerfritt
Flicker Free
Delta E<2 (sRGB)
Delta E<2 (sRGB)
Skåpinformation
Ram typ (fram)
3-sidig ramlös
Ram färg (fram)
Svart, Röd
Ram finish (fram)
Strukturerad
Skåpfärg (baksida)
Svart, Röd
Skåp finish (baksida)
Strukturerad
Avtagbart stativ
Kensington-lås
Quick release function
VESA Mount Support
Yes
Ergonomisk information
Luta
3.5° ±1.5° ~ 21.5° ±1.5°
Höjdjustering (mm)
130mm
Vridning
30° ±2° ~ 30° ±2°
Spelfunktioner
Spelstil
Shooters, MMORPG, Action, RTS, Racing
Spelläge
RTS, FPS, Racing, Gamer 1, Gamer 2, Off
Spelbekvämlighet
G-menu
Låg eftersläpning
Spelfärg
Skuggkontroll
Minskning av rörelseoskärpa
Crosshair / Dial Point
Ramräknare
Hållbarhet
Carton material
EPS
Effektförbrukning
Strömförsörjning
Intern
Strömkälla
100 - 240V 50/60Hz
Strömförbrukning på (typisk) i watt
59
Strömförbrukning viloläge i watt
0.5
Strömförbrukningen av i watt
0.3
Anslutningsinformation
HDMI
HDMI 2.0 x 2
Digital HDCP (HDMI-version)
HDCP 2.2
DisplayPort
DisplayPort 1.4 x 2
USB-hubb
USB-hubb hastighet
USB 3.2 (Gen 1)
USB-nedströmuttag
4
USB-snabbladdningsuttag
Ljudutgång
Hörlur ut (3,5 mm)
DP HDCP version
HDCP 2.2
Produktmått
Produktmått inkl. bas (BxHxD) mm
808.3 x (398.2~528.2) x 237.4
Produktmått exkl. bas (BxHxD) mm
808.3 x 367.5 x 102.9
Förpackningsmått (BxHxD) mm
903 x 280 x 548
Packaging dimensions (WxHxD) mm (CN)
903 x 280 x 548
Bruttovikt inkl. förpackning (i kg)
12
Nettovikt exkl. förpackning (i kg)
8.02
Gross weight incl. package (in kg) (CN)
12
Produkt utan stativ (kg)
6.51
Vad finns i lådan
HDMI-kabel
1x
Displayport-kabel
1x
Strömsladd
Annan information
EAN
4038986111331
OSD-språk
Engelsk, Ukrainska, Turkiska, Polerad, Tyska, Portugisiska, Spanska, Franska, Finska, Koreanska, Japanska, Kinesiska (förenklad), Kinesiska (traditionell), Svenska, Nederländska, Italienska, Kroatiska, Ryska, Tjeckiska
Garantitid
3 år
Maximal upplösning med kontakt
Optimal upplösning DP
3440x1440@180Hz
Optimal upplösning HDMI
3440x1440@100Hz
