grep & hidden string alias'
Viscarious
951 (0.15/day)
Processor AMD Phenom 9850BE
Motherboard ASUS M3A32MVP Deluxe 790FX
Cooling ZALMAN CNPS9700
Memory Crucial Ballistix Tracers 4G (1G x 4) 800Mhz CAS4
Video Card(s) VisionTek HD3870 + a VisionTek HD3870 OC Edition Xfire'd
Storage 320G WD SATA + 160G
Display(s) Gateway HD 19" 4ms
Case Raidmax Ninja
Audio Device(s) Creative X-Fi XtremeGamer
Power Supply 650W Antec Earthwatts
Software Windows Vista 64bit SP1
Benchmark Scores candle_86 is a fanboi
I'm trying to find all the hidden files in a directory with the string alias using 'grep' command.
I've tried many diff combos but my terminal keeps locking up.
grep -ls .string seems to be what I've been using a variation of.
Yet still, lock ups.
Have you gone in with all permissions first?
Hmm. I didn't think I'd need to.
I used 'grep -ls .*' and it comes back with all the hidden files. Both as su and as my norm user.
I'm not sure what this paper means by 'string alias' nor how to use it in conjunction with grep.
Go in and use su- and use your root password and then try it out.
