xbonez
- Nov 29, 2010
- 1,182 (0.22/day)
- Philly, PA (US)
System Name | Winter |
Processor | AMD Phenom II x4 965 BE @ 4.0Ghz |
Motherboard | MSI 790FX-GD70 |
Cooling | Corsair H50 Liquid Cooling |
Memory | 2 x 2Gb Gskill Ripjaws 1600Mhz (7-7-7-24@1.6V) |
Video Card(s) | Asus GTX 470 @ Stock (Zalman VF3000 cooler) |
Storage | 2 x Samsung Spinpoint F3 500GB (RAID 0) |
Display(s) | Hanns G 28" @ 1920x1200 |
Case | Antec 1200 |
Audio Device(s) | Onboard -- TosLink --> Z5500 |
Power Supply | Corsair 850TX 850W PSU |
Software | Win 7 64-bit Ultimate |
I am trying to set the timings for my RAM in my BIOS.
This is the RAM I have:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 ...
This is the current CPU-Z config
It defaults at 9-9-9-24@1.60V. I manually changed it to 7-7-7-24@1.65V. However, the FSb: DRAM ratio is set to auto, and so my RAM is running at 1333Mhz. It is rated at 1600Mhz, but should I change it to that?
I've heard in case of RAM frequency, the higher is not always better and it has to stay in sync with the FSB. I'm not really sure about OC'ing and playing around with RAM as I've never done it before. So, whats your advice guys?
Also, under DC mode (in the pic above) it says Unganged. Does that mean its not running in Dual Channel, or does that mean something else?
