GSYNC lowering GPU Usage Resulting in Lower FPS?
8 (0.00/day)
Bakersfield, CA
System Name Protoss V2
Processor Intel i7-7700K @ 4.9 GHz
Motherboard Asus Maximus IX Hero Z270
Cooling NH-D15
Memory Corsair Vengeance LPX 16GB 3 GHz
Video Card(s) Nvidia GTX 1080FE SLI @ 2.1 GHz
Storage Samsung 840 Evo 500 GB; WD Black 1 TB x2 RAID 0
Display(s) Asus ROG Swift PG278Q
Case Corsair Air 540 White
Audio Device(s) N/A
Power Supply EVGA SuperNOVA 850G2
Mouse Corsair M65 RGB
Keyboard Corsair K95 RGB
I'm not sure if this is just me on here but I've noticed something very annoying these past couple of days. This is true to all of the games that I play. I've got a 7700K overclocked to 4.9 GHz and two GTX 1080s overclocked to 2.1 GHz.
GSYNC OFF in Witcher 3: GPU usage are pegged at 99% giving me around 130 - 140 FPS wherever I go in the game. Even in the most demanding city in game which is Novigrad.
GSYNC ON in Witcher 3: GPU usage is around 80% - 90% and I get around 120 FPS max and it wouldn't even go higher than that. Sometimes, I even dip down to 89 FPS, which is really annoying.
I know that it's still above 60 FPS, but my point is, my GPU isn't being utilized to it's maximum potential with GSYNC enabled and I'm at my witts end. Here are the things that I've done to try and fix this problem:
- Uninstalled drivers using DDU and reinstalled latest ones.
- I also tried rolling back 3 drivers back to no avail.
- Reinstalled Windows 10 install and reinstalled the games and still nothing.
- Reseated the GPUs and the HB SLI bridge
- Reseated theh RAM
None of these methods worked. The ONLY solution I've found is disabling GSYNC. Which makes the whole module pointless.
Please, if anyone is having this same problem, have you done anything to try and relieve this?
Kanan
Tech Enthusiast & Gamer
3,517 (0.99/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Sounds like a really special problem, try Nvidia or Witcher 3 support.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
If I may offer up my humble advice. I find that when ever a problem reveals itself in regards to a video card if you're running crossfire or SLI it only complicates the situation. Remove one of the video cards,and see if you can replicate the issue that way(running a single gpu). I'm willing to bet that you won't be able to. I look forward to finding out if I'm right or wrong ,hopefully the former.
Kanan
3,517 (0.99/day)
Europe
VR HMD Still nope
If I may offer up my humble advice. I find that when ever a problem reveals itself in regards to a video card if you're running crossfire or SLI it only complicates the situation. Remove one of the video cards,and see if you can replicate the issue that way. I'm willing to bet that you won't be able to. I look forward to finding out if I'm right or wrong ,hopefully the former.
Yeah it's probably a special SLI/Gsync driver problem. AMD is fixing issues like that all the time @ Freesync/Crossfire/Fullscreen/Max window and whatnot. In the end, SLI/CF makes everything complicated and produces errors en masse.
1,181 (0.17/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
This looks normal. The minimum time between frames with gsync on is capped at ≈7ms which will cause reduced GPU usage any time the frame gets drawn faster then this.
8 (0.00/day)
Bakersfield, CA
Cooling NH-D15
Audio Device(s) N/A
I have done these. Both of the cards run at 99% load all the time if there is only one.
I really wish that Nvidia focused on this more than releasing a new Titan GPU. Quite annoyed right now really.
So I shouldn't be worried then? But here's one more thing, shouldn't the GPUs be utilized 99% or until they hit the frame cap?
1,181 (0.17/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
The closer you get to the frame rate cap the less GPU utilization you will get. With a SLI setup, frame pacing will decrease the utilization even more and reduce the frame rate abit to avoid any micro stuttering.
Doesnt the game look and feel smoother with Gsync on even though you are only getting 100fps compared to 130fps with no sync?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
I have done this
so You are able to replicate the problem Even when you have only a single GPU installed in the PC?? or does it go away when only one is installed? i dont mean just remove the SLI bridge, i mean actually uninstall the 2ndary GPU entirely. i just want to make sure im clear on what your saying.
5,048 (0.92/day)
València la Vella
Hi, mate. I am also a G-Sync user here.
What's your monitor frecuency? Maybe 120 Hz?
G-Sync limits the provision of frames to the monitor capacity, so it is only "as per design" to create less frames (so less intensive GPU usage). The room that this leaves is for you to turn up the details, view distances, etc. in the game. More stuff but at a fixed frame rate. ; )
r9
3,300 (0.54/day)
System Name Primary|Secondary|Poweredge r410|Dell XPS|SteamDeck
Processor i7 11700k|i7 9700k|2 x E5620 |i5 5500U|Zen 2 4c/8t
Memory 32GB DDR4|16GB DDR4|16GB DDR4|32GB ECC DDR3|8GB DDR4|16GB LPDDR5
Video Card(s) RX 7800xt|RX 6700xt |On-Board|On-Board|8 RDNA 2 CUs
Storage 2TB m.2|512GB SSD+1TB SSD|2x256GBSSD 2x2TBGB|256GB sata|512GB nvme
Display(s) 50" 4k TV | Dell 27" |22" |3.3"|7"
VR HMD Samsung Odyssey+ | Oculus Quest 2
Software Windows 11 Pro|Windows 10 Pro|Windows 10 Home| Server 2012 r2|Windows 10 Pro
With any sync you can drop frames to the desired FPS but can't force the GPU outperform its maximum.
So its sound about right to me.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Any type of syncing technology is going to lower the framerate and GPU utilization. The whole point is to only render a frame at the exact time the monitor can display it. Gsync(and Freesync) all the monitors refresh rate to be adjusted on the fly to allow the best possible mating of rendering frames to monitor displaying them. But it can only go so far. The syncing still causes the GPU to wait on the monitor to be ready, and this cause lower framerates and hence lower GPU utilization.
IMO, turn the framerate counter off. You're mind gets too caught up on the framerate to notice that even at the lower framerates, the gameplay is smoother with no tearing and the input lag is non-existent.
3,871 (0.74/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
^^This. If you are hitting your smoothness target, that's all that matters. Utilization is meaningless if it hampers smoothness so placing it as a barometer is again backwards.
3,014 (0.62/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
120 Hz is 8.33 ms per frame
His gsync monitor goes up to 165 Hz
Nope, he said single gpu is at 99% usage ... prolly needs to reduce resolution to hit those framerates on 1 gpu anyways
Yeah, smells like effect of SLI frame pacing combined with high fps gsync, although I'd never call it a problem
1,181 (0.17/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Yeah i saw that, but i just wanted to clarify for certain.
I agree it seems like frame pacing,
3,014 (0.62/day)
Zagreb, Croatia
Cooling Corsair AIO
165Hz is ≈6ms per frame
Are you saying although panel can refresh in 6 ms, gsync is limited at around 7 ms? I was pointing out that OP is at 8.33 ms and that silly 1.33 ms difference that bugs him is due to SLI pacing.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
I think since there's a physical connection between the two video cards people tend to forget that there is some delay in SLI, GPU's communication.
Black Haru
1,567 (0.28/day)
Indiana
Hang on... iirc the way gsync works is two way comunication between the monitor and the gpu so that the monitor only updates when there is a new frame ready. All gsync monitors have a range in which this function works, usually it's a minimum of arpund 30fps up to the monitors max refresh rate. But if ypur monitor caps lower than that with gsync, wouldn't it comunicate back to the gpu to throttle it back to the limit?
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
I don't think there is any two way communication. I believe the way it works is the GPU controls the refresh rate of the monitor, so that the monitor refreshes when there is an image ready. It basically varies the monitors refresh rate on the fly to exactly match the framerate(instead of adjusting the framerate to match the monitors refresh rate).
The two still have to be in sync, and that induces overhead.
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Less frames are drawn = lower GPU utilization.
Why is this so baffling ?
G-Sync limits your frame rate to whatever refresh rate your monitor has. In addition to that I am sure G-SYNC still introduces some performance hit in order to maintain sync between the monitor and the GPU. I see nothing out of the ordinary here.
1,778 (0.30/day)
Little Rock, AR
System Name Gamer
Processor AMD Ryzen 3700x
Motherboard AsRock B550 Phantom Gaming ITX/AX
Memory 32GB
Video Card(s) ASRock Radeon RX 6800 XT Phantom Gaming D
Case Phanteks Eclipse P200A D-RGB
Power Supply 800w CM
Mouse Corsair M65 Pro
This is exactly what GSync is supposed to do... lower the framerate (and by proxy, GPU utilization if your GPU's are overpowered) to match the monitor's refresh rate, and conversely, to lower the monitor's refresh rate to match the GPU's framerate if the framerate dips below the monitor's max refresh rate.
What's the problem?
3,014 (0.62/day)
Zagreb, Croatia
Cooling Corsair AIO
What's the problem?
We kinda stopped calling it a problem :laugh: also with gsync only the gpu controls when display does its refresh, display can do 165 Hz but gsync tops out at 120 Hz here and only in SLI ... it's curious because several factors are in play such as gsync overhead and SLI frame pacing that driver does to combat micro stuttering ... and as usual the rest of the TPU is interested in this topic much more than the OP
2,201 (0.49/day)
Deez Nutz, bozo!
System Name Rainbow Puke Machine Reborn :D
Video Card(s) ASRock ARC B580 Challenger 12GB (Stock)
Software Tweaked Windows 11 Professional x64 (Update 24H2) OS
I dun see G-Sync a problem unless OP sees it as one. Any game turned up to Max while hitting over 60fps is more than enough for most folks IMO...
5,048 (0.92/day)
València la Vella
Gaming is getting complex again these days with all this monitor related birdshit after nearly 2 peaceful decades since Glide/DirectX bloodbaths ;)
23,870 (6.16/day)
If you're being realistic, when you can hit above 100 FPS consistently with any setup, Gsync becomes a problem rather than a solution.
Remove Gsync, use Fast Sync, and you're tear free and maximizing FPS. If your FPS fluctuates too much, use Gsync and accept what it does for you :)
But this whole thread is the perfect practical example of why I'm convinced Gsync is worthless for any high end rig. OP has also concluded that effectively Gsync is pointless right there in the TS. Too bad it took a purchase of it to get there ;)
