GTX 1070 GPU-Z Asic Quality Issues
chan0_
2 (0.00/day)
Hi all, I have an MSI GAMING GTX 1070 and I was trying to read the asic quality on the card from GPU-Z, but GPU-Z tells me ASIC quality isn't supported on this card. I'm running 1.9.0 and have updated all drivers on my GPU. Any help?
There is no help currently. W1zzard (creator of GPU-Z) is still working on a means to extract that information from Pascal.
Welcome to TPU!
Yes download this version...: GPU-Z.0.8.7
but my EVGA GTX 1070 FTW shows me an Asic of -60% if it's this true, I don´t now ?!
I heard the most 1080´s show 100% thats is a sign that NVIDIA bad batches used for the 1070´s.
Please write your values please ;)
ASIC quality reading is somewhat flawed to me. supposedly all card's are designed the same. if there is a flaw in the design GPU-Z wont detect/read it. some have cards on high volts and low watercooled temperature. other low volts and bad coolers. but it judges you over volts. somehow this doesn't work for me.
It's like a program that tell's you how to set your card so it can have the longest lifespan. nothing alse. it would probably give you a score of 200% if you lowered all clocks to half of what it is made for and undervolt it. it does not say anything about quality, just lifespan probability.
I assume that just means it doesn't work.
