Gtx 1070ti Display port no signal
37 (0.01/day)
Hey guys,
So I got G2460PF AOC monitor 144 hz, i used to have DVI on it was running perfectly with it, i bought display port cable today and when i plugged it in it says no signal, tried both Display port inputs on Graphics card , and even on motherboard but still nothing , I have asus maximus IX hero Motherboard,
P.S They tested display port and it is working fine .
Try plugging the DVI cable back in and dropping the Resolution an than try the DP again
''P.S They tested display port and it is working fine .'' on the card ? monitor ? the cable on there stuff ?
if you look around ports not working goes back to the NVidia 900 series . lot of guys with this [sadly I use a dvi-I to hdmi on mine still even under this 4k ..lol.. ]
I googled ''G2460PF AOC monitor displayport not working'' a few threads on it as well . one may offer a best answer to help ?
try what monkey100 said seems to helped others ?
ttps://www.reddit.com/r/ultrawidemasterrace/comments/6mzy1o/display_port_no_signal_suddenly_aoc_35_1440p/?st=jlnx9ggs&sh=1763dcda#bottom-comments
your not alone on these port issues just finding the right reason why is the trick
just to add may shut down reboot to safe mode then reshut down unhook what your using and hook up the display port cable then reboot and see if the NVidia driver catches the change or instead of safe mode just first uninstall the driver do the cable swap boot back up and reinstall the NVidia driver [if win-10 ??????? your on your own with that malware service ]
Tried different cable, updated firmware ( said already updated ) , safe mode etc etc, last time I had DP cable it was giving only 60 hz , that's why I updated the DP to get 144 hz
I looked at a few more on this and seems like you turn off the monitor and all for like 2- 5 min. ? I just got back to like the 3ed one from NVidia forums with that answer and all said it worked for them ?
just so many and so many resolves if so...
https://forums.geforce.com/default/...-gtx-1070-no-signal-when-using-displayport/2/
post after post
maybe just go with this and cut the chase ?
Certified
18Gbps
compare to the rest for 10 bucks or so / no thrills full hdmi speced .
https://www.amazon.com/Monoprice-11...01GCGKI3O/ref=cm_cr_arp_d_product_top?ie=UTF8
unless I missed it this manual shows to be just plug and play
https://www.manualslib.com/manual/1099940/Aoc-G2260vwq6.html?page=12#manual
maybe see if aco has a new updated driver you may need for todays use with it ? like something needed for malware use [I mean win-10 ]
sadly they don't allow to review the notes of any driver its download /use at own risk
http://www.aocmonitorap.com/my/download_driver.php
may look at this ?
https://www.techpowerup.com/forums/...ios-update-can-fix.244981/page-2#post-3853540
