justwondering
- Jul 2, 2019
- 5 (0.00/day)
Okay I have a few graphics card, so no fault with the motherboard , psu , monitor , PSU etc ( z97 , 24inch, Corsair RM1000i, 16gb ram, windows 10 64bit) , I have tested my system with my RTX 2080ti, that works fine etc.
But my backup card a GTX 1080 will not display any output, if I load up windows using the onboard Intel graphics I can see the card and that the drivers are installed, but when checking via GPUZ (the latest version) the card shows up in the drop down box, it shows the drivers are installed, subvendor info, device id, bus interface, shades and various other information, but most noticeably what is not showing, is the
Memory type shows Unknown (I've checked the ram on the card it shows as Micron on the chips)
memory size as Zero
pixel rate Unknown
texture fillrate Unknown
memory size zero
bandwidth unknown
GPU clock 0mhz
default clock 0Mhz
Memory 0 Mhz
I have downloaded and flashed successfully using NVFLASH (64bit version) the correct bios from techpowerup database and I have also a GTX 1080 Founders edition rom which clearly stated as using "Micron memory" but no joy after a reboot, same information shown.
I have tried reinstalling the drivers and rebooting but that did not make any difference.
Any help and advice welcome
memory size as Zero
pixel rate Unknown
memory size zero
bandwidth unknown
GPU clock 0mhz
default clock 0Mhz
Memory 0 Mhz
