- May 18, 2011
- 1,161 (0.22/day)
Processor | 7800X3D |
Motherboard | ASRock X670E Lightning PG |
Cooling | Thermalright Phantom Spirit 120SE CPU cooler, 3x 140mm, 1x 120mm case fan |
Memory | 32GB G.SKILL Flare X5 DDR5 6000 (PC5 48000) F5-6000J3038F16GX2-FX5 |
Video Card(s) | Zotac RTX 4070 Super Trinity Black |
Storage | 2x WD SN850X 4TB, 2TB P31 SK Hynix, WD Black 6TB, WD Red Plus 12TB |
Case | Fractal Design Definse S |
Power Supply | Seasonic Focus 750 |
Mouse | Logitech Pro |
Keyboard | Corsair Strafe Cherry MX Silent w/red LED |
VR HMD | Meta Quest 2 |
Software | Win 10 Pro |
Yesterday I received a GTX 560ti 2GB from EVGA. The first time I booted it up it worked flawlessly. The second time I tried turning on my PC with this card, the monitor would not display anything. Again it did it this morning. The fan was indeed spinning both times. I heard a POST message both times as well.
To fix the issue in both cases, I turned off the power, opened my case, and inspected the card/power cables. All three are firmly inserted. After turning the power back on it loads into Windows fine. Yesterday I played BF3, ArmA 2 and some other games for a few hours with no issues.
When the card does boot with the system, the actual "fan speed increase time" is noticable longer than my previous GTX 260.
Is there something wrong with my card?
PSU specs:
System specs:
Antec Earthwatts 500 - I was told this would be plenty of power (had no issues when gaming). 2.5 years old.
ASUS M3N78 Pro Motherboard
Corsair XMS2 - 4x DIMMs, 8GB total
AMD 965
WD FALS HDD
Samsung 223F DVD/CD Drive
2x case fans
1x PCI Card
GTX 560ti 2GB - Upgraded from GTX 260 216 Superclocked
Some updates of my findings:
I've tried replicating the above a few more times. I reseated the card and power cables beforehand. Same issue. I have determined the following:
1) When I turn on the PC (from a previous normal shut down via Windows) the video card fails to display anything. I can not see my motherboard POST screen or Windows. The fan spins, but there is nothing displayed on my screen. My monitor acts as if there is no video card (light is red rather than blue). However, after a delayed time period (10-15 seconds longer than normal) I do hear the POST beep. I hear the HDD accessing, and it seems as if Windows is loading. I have tried both DVI ports on the video card.
2) When I unplug the power, and replug it in, turn it on, it works fine.
For some reason a normal shut down disables the card from displaying anything upon the next start up. Unplugging the power fixes this issue.
This makes me think it is the video card. Yesterday I played BF3 continuously for a few hours with no issues, I would think that would draw more power than at POST? Does anyone think it is the PSU being insufficient or a video card issue?
PSU specs:
System specs:
AMD 965
WD FALS HDD
2x case fans
1x PCI Card
