GTX 970 and TV scaling
3,433 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Cooling Stock Intel Cooler
Video Card(s) Dell RTX 3080
Display(s) LG 32" 1440p
Case Phanteks Evolve itx
so this is an interesting issue.
My friend who has my old GTX 970, has it connected to his 1080p TV. So after connecting it and setting to 1080p, of course it is stretched passed the bezel meaning I have to scale it. No problem. So I scale it.
Issue is though, every now and then, it just goes back to default for whatever reason. Just automatically, from sleep mode, goes back to standard display before setting resolution.
Any reason why this is happening?
As a note, he also has it set on an HDMI splitter. Could that also be the issue?
Setup is:
Core i5 3570K
Asus mobo (forgot which one)
16gb DDR3 1600mhz ram
MSI GTX970
Corsair 550W Gold PSU
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i dealt with this for years on my daughters PC, which was hooked to our TV. frustrating, and annoying. never got it resolved, but your not the only one FWIW also a gtx970, in my case though, it MIGHT have been caused by irregular resolution, as the TV was older, and 1080i, not 1080p
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Actually there is a problem with that, there is no reason why it should be stretched unless 1080p isn't the native resolution of the TV. I think there is something else amiss here.
3,433 (0.48/day)
Canada
System Name PCGR
Processor 12400f
Like what?
I had this same thing happen to me with a TV and my AMD card in the past, and I never figured it out.
On a computer screen, works perfect. On a TV? Nope.
12,062 (2.54/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
TVs try to be oh so helpful, I have the same issue on my GTX 1060 on any TV I connect to. You gotta fumble around with the TVs settings, not the computer's.
9,800 (3.23/day)
Case Phanteks NV7
Like what?
1080p is 16:9, there should no scaling needed or stretching. Are you really sure that's a 1080p TV ? Try it without the splitter .
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
Exactly. I had KODI connected to a 1080p TV and it did the same thing every time it was rebooted. Fun times...
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Yeah need to find the TVs “Pixel Match or 1:1 or my old Samsung calls it Just Scan.
