- Apr 28, 2016
- 98 (0.03/day)
- california
System Name | Madness |
Processor | 6700k delidded 5.0ghz from silicone lottery |
Motherboard | Msi z270 m5 |
Cooling | xspc cpu block , ek pump/res , alphacool 360 rad , ek fc x2 , monsoon fittings |
Memory | corsair dominator platinum16gb with light bar kit |
Video Card(s) | Msi 1070 seahawk x2 |
Storage | adata sp550 256gb , seagate 1tb |
Display(s) | hp 24' monitors x3 |
Case | Phanteks enthoo evolve tempered glass |
Audio Device(s) | Samsung 5.1 surround system |
Power Supply | xfx 1250w pro series , custom cables |
Mouse | Logitech g403 |
Keyboard | Logitech g11 ,painted white and black |
So here's a simple little trick that I've been doing for years now to add a little "pop" to a case , or any other part with recessed lettering or any logos .
all you need is :
some acrylic paint
rubbing alcohol
paper towels
a small brush
and something flat. I'm using a sharpening stone.
alternatively , you could use a q-tip , and a clorox wipe , instead of alcohol a paper towel and a brush.
take your part you want to paint from the case(or whatever part you're doing) and start dabbing the paint into the area that you want to paint
Before the paint is completely dry , get your paper towel with a little bit of alcohol(or clorox wipe) as flat as possible on your flat surface (sharpening stone in this case). this keeps it from wiping away more open shallow areas.
start a side to side motion of rubbing off the paint from above the recessed area. this may take a couple trys. If the paint is rubbed away in undesired areas , just repeat the process.
it shouldn't take long before this is your final result
but why stop there?
seems easy enough right? Its also pretty easy to remove this mod with more alcohol should you decide to change paint colors, or just remove it entirely.
hope you all enjoy this . and if any one uses this post a pic here . i would love to see what you all can do with my little trick.
all you need is :
some acrylic paint
rubbing alcohol
paper towels
a small brush
but why stop there?
