[Guide] Make and sleeve your own extension cables!
Crys1s_Gam3r
17 (0.00/day)
I originally posted this in the EVGA forums, but I though some of you might appreciate it. So without further rambling here's the stuff you'll need: ;)
Materials:
- 18 AWG stranded wire
- Molex male/female pins for Mini-Fit Jr. receptacle housings (aka "ATX pins")
- Molex Mini-Fit Jr. housings (aka "ATX connectors")
- 1/8" or 3/16" cable sleeve
- 1/4" heat shrink (with at least 3:1 shrink ratio)
Equipment:
- Wire cutter/stripper ($5-$15)
- Molex Mini-Fit Jr crimper ($20-$50)
- Heat gun ($20)
- Lighter ($2-$6)
- Scissors (dont go cheap... get a nice $5 pair ;))
- Xacto knife (a kit goes for about $15)
For the sake of this guide, we'll be doing a 12" 6pin PCIe extension. You can apply the techniques in this to all the extensions with Mini-Fit Jr connectors (24pin, 8pin, 6+2pin, 6pin).
Start off by cutting the wire at 12" intervals. When they're all cut, find the shortest wire and cut them all to be exactly that length. Even the slightest variation in wire length will make one appear to "bulge", so it's best to make sure they are even while it's still easy to adjust.
Next, strip off exactly 3mm on each end of each wire.
When that's done, it's time to get out your crimper. Different people have different crimping methods, this is mine: First, put the female pin face up in the crimper, and close it until it clicks once. This will hold the pin in place, freeing up your other hand. If you used wire from a spool, you'll notice that it forms a "C" when cut.
Take the top end of the C (I'll explain why later) and insert it as far as it goes into the pin in the crimper. Finish closing the crimper until it opens. It should come out something like this:
Then insert the male pin face up into the crimper, and close to hold it in place. Then grab the bottom end of the C (if the already crimped pin is face up, this bottom end should have no pin), and insert it flat into the crimper. It's important the the already-crimped pin is facing up while you crimp this pin. Otherwise the wire would have to twist from one connector to the other.
When all the wires have been crimped, you should have this:
There are plenty of sleeving guides online so I'll just post a quick picture guide of the process:
If you used an accent color, insert the female pin side into the male connector. Then find another that has exactly the same distance from the end of the heatshrink to the end of the sleeving. Insert it into a spot next to the accent color.
Continue around the connector in the same fashion. This will ensure the "heatshrinks" are even. Insert the opposite ends into their corresponding spots on the other connector, and you're done! Well, almost. If the heatshrink-evenness is still less than satisfactory, take an Xacto knife and carefully cut a small ring off the end of the heatshrink. Using the lighter, flick it over the cut part to make it less gray.
It now should look something like this:
Emphasis on having even heatshrink is obviously on the male end of the cable. Unfortunately, this may lead to the other end having not-so-even heatshrinks. This happened to mine:
If you're unhappy with it (although this is the end you don't see) - use some big heatshrink over the connector itself to cover up the unevenness. Like so:
Now - perfection: :)
I hope you found this guide useful, or at least somewhat interesting. Any and all feedback is appreciated, and if you have any questions don't hesitate to ask! :)
970 (0.17/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
Welcome to TPU Crys1s Gam3r :toast:
Nice easily understandable guide, even I could follow.
970 (0.17/day)
Granby, Qc. Canada
Crys1s_Gam3r
17 (0.00/day)
Hehe :D
This feature where the replies pop up without refreshing the page is pretty awesome BTW. :cool:
970 (0.17/day)
Granby, Qc. Canada
Hehe :D
A lot of nice and good people here to help you if you ever need it too :rockout:
Would you be able to post links to some places where you can find all the connector, wires and what not?
5,787 (0.94/day)
Switzerland, Heart of Europe
System Name Fractality 1.0
Processor Intel Core i7-860 @ 3.6GHz
Motherboard EVGA P55 SLI
Cooling Prolimatech Megahalems and four Fractal Design 120mm fans, sleeved
Memory 16GB Kingston Hyper RAM
Video Card(s) PNY GeForce 580 XLR8
Storage 64GB and 180GB SSDs / 1TB and 2TB HDDs
Display(s) 24" Acer V243W
Case Fractal Design Define R2, sleeved all I/O cables
Power Supply Corsair HX750W modular, sadly only stock sleeving
Software Win 7 64bit
Nice guide, you seem to know your stuff man.
Fitseries3
Eleet Hardware Junkie
15,508 (2.42/day)
Republic of Texas
he sells all this stuff i believe.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Any large chain hardware store carries all of this stuff. :)
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Ahhh, I thought he had access to all the cool toys;)
Nice guide. How closely to a Gigabyte blue PCB is your light blue color?
Fitseries3
15,508 (2.42/day)
Republic of Texas
i believe its all MDPC-X stuff.
any color they have he can get.
i ordered more black sleeve and im thinking about getting some red :D
i've talked to him about shortening my modular pcie cables since i have so many of them.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
I was kicking the idea around for like a 6" 24-pin in alternating blue and white for my UD7 that shows up tomorrow;)
Crys1s_Gam3r
17 (0.00/day)
Thanks,
Wire from conwire.com
Connectors from AC Ryan
Pins at Newark, molex part # 39000038 and 39000040
Sleeve and heatshrink from MDPC-x.com. I tried to organize a group buy seeing as I'm ordering from there again soon, but it was deleted within 5 mins of posting. :confused:
Or you could PM me for some, as fits has done. :)
Thanks man :)
I wish. :) I'm not sure about the Gigabyte boards, but I will post a pic soon of the sleeve next to jeans and other blue items for reference. :toast:
I'll reply to your PM when I finish typing this.
Polarman
1,626 (0.26/day)
Rimouski
System Name Polar's Dragon
Processor AMD Phenom II 975BE
Motherboard MSI 890FXA-GD65 (Bios 18.7)
Cooling Zalman CNPS 9700 Led
Memory Gskill 8GB DDR3-1333 (8,8,8,21)
Video Card(s) MSI HD6870 Hawk
Storage WD Raptor 250 - WD RE4 500GB
Display(s) Samsung T240 (1920 X1200)
Case Silverstone Raven 2
Power Supply PC Power&Cooling Silencer 750 (Red)
Software Windows 7 Home Premium 64Bit + SP1
Good guide. But this would be better in the modding section i believe.
Duffman
1,011 (0.16/day)
Mt. Pocono, PA
System Name Black Knight
Processor Intel Xeon W3520 @4.2Ghz
Motherboard evga Classified 760
Cooling Prolimatech Mega Shadow with Dual Noctua NF-P12 fans
Memory 6GB Corsair Dominator GT DDR3 (3gb x 2) 1600
Video Card(s) Sapphire 5870 Vapor-X
Storage Corsair P128 SSD for OS, 4 Samsung 500GB in RAID10 For Storage
Display(s) Samsung SyncMaster T240HD
Case Corsair Obsidian 800d Twin Zalman ZM-MFC Plus fan controllers
Audio Device(s) HT|OMEGA CLARO
Power Supply Antec Truepower 1000
Software Win7 64bit ultimate
Neat guide. I could have used this if i hadn't bought my new case.
5,226 (0.82/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
Very nice guide. If your looking for some nice sleeving at a hell of a price check this Ebayer out. I've dealt with him several times.
Crys1s_Gam3r
17 (0.00/day)
Thanks Duffman and kenkickr. :)
Kenkickr: PET is good, but IMO it doesn't get any better than MDPC. :)
8,519 (1.35/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
Sticky Request!!!!
Needs links where we can buy the sleeving and accessories.
5,226 (0.82/day)
Software Win 11 Pro
I agree with you but I know around here MDPC sleeving is EXPENSIVE! Don't make me re-sleeve my Corsair again J/K
Athlon2K15
HyperVtX™
7,909 (1.17/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
simply amazing crysis,i think im going to give it a shot sometime in the future
1,793 (0.32/day)
System Name Old Skool
Processor E6750 @ 3.6 ghz
Motherboard GA P35 DS3L
Cooling Xigmatek Dark Knight S1283v
Memory 4gb Kingston DDR2 @ 900mhz
Video Card(s) XFX 9800GT 512MB
Storage SAMSUNG 320gb
Display(s) VIEWSONIC vx2260wm
Case HAF 922
Audio Device(s) Realtek (on board) + Logitech x540
Power Supply CM 550w
Software W7 Ultimate 64
Nice and easy guide. I might try this but I have to add that this looks like a daunting challenge.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
All I can say is his work is amazing. I had talked with Crys1s a bit and we came to a quick agreement, and here is what he produced for me, a completley one off 24-pin extension for my GA P55 UD7. Have a look....
I think its going to look spot on in my rig...cant wait to get it Crys1s!
