H50 vs TRUE
ale86cuba
45 (0.01/day)
System Name aliona
Processor Q9550 @ 3.8GHz
Motherboard GIGABYTE UD3R P45
Cooling Corsair H50 CPU cooler
Memory 2X2GB DDR2-800 GSKILL
Video Card(s) SAPPHIRE HD6950
Storage 2X320GB RAID0, 1.5TB WD
Display(s) Mitsubishi 17"
Case CM Stacker 832
Audio Device(s) XFI Xtreme Music
Power Supply Corsair HX620
Software Win7 64bit
so i saw a sale at ncix and the corsair H50 at a cheap price, 40cad....i decided to buy it and see how it goes with my current system....do you think it will outperform my true? what mods can i do to my h50? like dual fans or better/quieter fan? any inputs are welcomed...thanks:rockout:
It will probably give you alittle better temps, but not enough over the TRUE to justify the price
If you can afford the H50 then go for it, it won't outperform the TRUE that much but you'll have alot more room in your case and a better looking cooler overall.
it will also be much silent :P if this "true" is anything like Thermalright Ultra 120 Extreme you listed in system spec.
i am using the H50 and whatever the overclock an voltage i never go higher then 60 on my quad,....
Ah yes to share my results on sandy bridge, so far @4.5ghz with 1.380 volts I don't go over 72 D/Celsius
Umm, the H50 is clearly the louder of the two. The True has no pump noise. I actually just replaced my lapped true with an H50 and performance was about the same, within a couple of degrees.
The H50 is a nice space saver and gives you the option to pump the heat directly out of your case which is nice.
