HAF 932 R3.0
78 (0.01/day)
Dubai, UAE
System Name Haf nuebe tres dos
Processor AMD FX-8320 @ 4.62ghz
Motherboard Asus Sabertooth 990FX R2.0
Cooling Ek custom water-cooling
Memory Corsair Vengeance 4x4gb DDR3 @ 1600Mhz
Video Card(s) EVGA GTX 780 SC with ACX cooler
Storage Sandisk Extreme 120gb SSD, Toshiba 128gb SSD
Display(s) Samsung 22" LED 1080p
Case Cooler Master HAF 932
Audio Device(s) on board realtek hd audio
Power Supply Cosair TX850w
Software Windows 7 Ultimate 64bit, Windows 8.1
Benchmark Scores 3Dmark Vantage 42000+
Specs:
HAF 932
AMD FX-8320 @4.62ghz
ASUS Sabertooth 990FX R2.0
Corsair Vengeance 16GB @ 1600mhz
Corsair TX850W
Corsair SP120 x8
Enermax fan controller
Sandisk Extreme 120GB SSD
Toshiba 128GB SSD
EK 360XT and Ek 240XT Rad
Zalman cooler
EK AMD LTX block
EK Dominator Ram block
EK-FC Titan water block
EK Compression fittings, 90 45 adapter fittings
EK top res with pump variable speed
3/8 5/8 primochill black tubings
custom strip leds
Mods:
simple spray paint, removed all drive and optical bays. cable management in the back of the mobo tray. Custom strip leds and psu shroud.
keep it super clean and tidy.
Clean and not intrusive with weird LED lights and quite elegant. This is an easy 8 but I'll give you a 10.
Thanks for the vote mate. cheers.. can't understand why he gave 1 for just not seeing the whole case. anyway, wanna see your build too. and drnesh's too.
Mod case without modding. I'm not jealous or something, just want to see more custom case and some new idea. This build is 10/10, so nicely done but not modded.
Mate, you mean removing the drive and optical bays and spray painting the case is not a MODIFICATION? Just couldn't understand why you're rating our rigs as "worthless" even the other full watercooled rig that you've rated previously is same. Are you a watercooling hater? Nobody's here saying that your jealous man, except you did..
It looks like what he means to say is you are only showing the hardware.
I think he means he wants to see ascetics changes to the exterior of the case.
I gave 5, previous i give 1 and sad that will change that when see case, not just interior. Yeah, I didn't see paint job and LC is MOD for sure but need to be seen from distance to see big picture and how appeal together. You don't watch case from that distance, with head in your rig, you put that on a desk. So, this rig is 8 for sure but people need to stop upload just fragments of case. If moderator can ban my first vote (1) and erase one of my post then can do something about that too.
