hard disk problem ,i do format put files inside then after few rebots need format it again
Status
Not open for further replies.
israrami
19 (0.01/day)
Israel, Tel Aviv
Processor INTEL I7 3770K 3.5Ghz @ 4.5
Motherboard Z77X-UD5H
Cooling Antec Mercury 360 Liquid Cooling
Memory 8GB x 4 G.Skill 2400Mhz
Video Card(s) GIGABYTE 980GTX G1 GAMING 4GB OC
Storage Samsung EVO850 250GB , 8TB X 2 SEAGATE 7200RPM - (need arrived)
Display(s) LG 24MP58VQ-W - WHITE
Case Fractal Design Define R5 - WHITE
Power Supply Seasonic PRIME Ultra Titanium 1000W - (need arrived)
Mouse Logitech G500s
Keyboard Logitech G510
Software WIN10 Pro
the title,
(Seagate Hard disk,)
what can be a problem?
1,740 (0.64/day)
BGD
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling Xigmatek LOKI SD963 double-Fan
Memory 64Gb DDR4 2666Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb
Case Lian Li
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3189,Cinebench R20=3791.Passmark=30689,Geekbench4=32885
Well you didn´t explain all details but from what you said your HDD is probably dying....but to make sure you should check your HDD with HDD Sentinel program to see your current performance and disk health...GL
rtwjunkie
PC Gaming Enthusiast
13,909 (2.42/day)
System Name Bayou Phantom
Power Supply Seasonic X-850
Well, it would be very helpful for you to provide the rest of your system specs in your profile. Problems usually exist in a system, so interaction with other parts is important.
Also, have you scanned with Seagate Tools, or Crystal Disk Info or other tools?
Since it shows up in Windows, even if to format, at least it CAN be scanned, because that means it hasn’t died.
re0
14 (0.01/day)
Could be a sign of a failing drive. However, we need more information such as whether you have heard any odd noises with the drive such as clicking or scraping (which could indicate a read head issue). Perhaps you could fill in your profile with your system's specifications or list them as a reply then we can better tailor responses to your needs.
If you had nothing important on the drive to recover, I would just proceed to use a utility provided by the hard drive manufacturer (in this case, SeaTools) where you can check S.M.A.R.T. and run generic read tests. Perhaps someone who uses the utility the most can comment on which tests would be best in this case.
dorsetknob
9,105 (1.30/day)
at the moment its anyones guess as to what it is
Failing Hard Drive
Check the Drive with the tools suggested above
Do not put any files you value on this Drive
Off the top of my head its probably going to show
Sector reallocation count to high =Failing Drive
But we Don't know until you run some Diagnostic Software
FireFox
The Power Of Intel
7,507 (2.02/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
@israrami
Aren't you the Seasonic prime 1000w titanium or Evga supernova 1000w guy?
if yes i just wanted to be sure;)
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Processor Rocket Lake Core i5 11600K @ 5 Ghz with PL tweaks
Cooling Thermalright Peerless Assassin 120SE + 4 Phanteks 140mm case fans
Memory 32GB (4 x 8GB SR) Patriot Viper Steel 4133Mhz DDR4 @ 3600Mhz CL14@1.45v Gear 1
Video Card(s) Asus Dual RTX 4070 OC
Mouse Coolermaster Storm Octane wired
Keyboard Element Gaming Carbon Mk2 Tournament Mech
Software Win 10 Home x64
@israrami
I would guess you already know the answer to your question :D
dorsetknob
9,105 (1.30/day)
That is one of his Previous two threads :)
israrami
19 (0.01/day)
Israel, Tel Aviv
Software WIN10 Pro
@israrami
yes what the problem with that i really not understand why this site so care about threads, is look that site can close and crash from threads,
and you in all my threads found, i don't understand what your problem with me, the people here soo cold, i come from israel and peoples and service very warm
Instead of helping, you concentrate on nonsense
I would not be surprised if little children are hiding behind the keyboard
Instead of helping you concentrate on nonsense
this the hard disk info in HDD Sentinel
thank you for peoples that really help
and not deal with nonsense
rtwjunkie
13,909 (2.42/day)
Ok, your SMART looks ok on a quick look on a phone, which is a little harder to see.
Have you tried putting the hdd in a different SATA part?
Have you tried a different SATA cable?
Did you install the motherboard chipset drivers on your pc?
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
OP, people are trying to help you but you ignore their questions and then you wonder why they get frustrated, you have been asked to provide your full system specs, you have not, you are not helping yourself therefore, as for me, I am grateful that you think I may be young, at 58 I am rarely called that anymore :D
Edit: from your screenshot it would appear that the drive is not failing, that's why it's important you tell us your specs.
israrami
19 (0.01/day)
Israel, Tel Aviv
Software WIN10 Pro
thank you for respond friend, amm, i try before few time change sata cable for other and about driver i install and driver computer in App call "Driver Booster"
is found all drivers and install it first
this drive can be empty from format then i will put some files then the drive need again format can't enter to him, and i again recover all last files with recuva software
1,042 (0.36/day)
Pristina
System Name My PC
Processor 4670K@4.4GHz
Motherboard Gryphon Z87
Cooling CM 212
Memory 2x8GB+2x4GB @2400GHz
Display(s) HP envy 32 1440p
Case CM Mastercase 5
Audio Device(s) Sbz ZXR
Power Supply Antec 620W
Mouse G502
Keyboard G910
Software Win 10 pro
Your HDD controller is busted so don't waste more time on it just throw it to trashcan or open it and take magnets+disc and trash other parts.
521 (0.22/day)
Hello,
if the problem is not the HDD (from your screenshot), then it might be the SATA cable or the SATA port on your motherboard.
Make sure everything is plugged fine and don't unplug it without closing your system (just to be sure...).
Edit;
You mean, in the harddrive?
Else, if it's a recent PC, the SATA Controller is in the CPU so the chance of it being busted is pretty low.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Not sure why you bring up the subject of another thread, 57 is surprising as I am 58 although a year is better than nothing. All I ask of you is to listen to the advice given and help others to help you otherwise all will happen here is you will get more threads closed...…….. even my patience can fail me at times.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
He did, he asked a question, I answered, seems you don't care to listen so as you have dragged this thread off topic this one is closed too.
Status
