Hard drive "burn in" testing software?
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Picked up two WD Easystore 10TBs at best buy. Will take the drivers out and upgrade my QNAP NAS.
I'd like to stress test them overnight before cracking the cases open. What software is up for the task, Crystal Disk or Diskmark? I did some googling already and specifics are sparse.
Thanks in advance....
I doubt testing it like that would net you anything.
^ Neither answer the original question, Christ
Edit:
Ok, on my own:
Wow, called out by name in the post
:D
Well, here is the actual workflow we follow for new drives. We generally order drives a dozen at a time from multiple vendors, and in the case of 11+1 arrays we take 2 of the drives each from 6 separate orders, so as to minimize the chance of linear production line failures. When we receive new drives, we follow the following steps.. First, we have a box setup just for drive verification testing (A Frankensteined older Supermicro with 8 LFF and 8 SFF slots, as well as 12 3TB SAS drives (11+HS in R6) which live in it fulltime). We run DBAN in DoD 5220.22-M mode, which does 7 complete passes (We used to use Gutmann (35 Passes), but found we had better success in breaking it up between coldstarts. Once the 7 passes complete, the box shuts down for anywhere between 1 hour and 2 hours (depending on how fast people get back to the box after the DVT email) and we start the 7 pass regime again.
The drives will continue in this pattern for 3 days.. Start.. DBAN.. Shutdown.. Lather.. Rinse.. Repeat..
Once the drives have survived this initial shakeout, they are placed into a test array (Generally 11 drives in the array and 1 spare). Data is then copied from a test array which is attached to an Areca 1882/HP Expander (The previously mentioned ~27TB Array) to the new array. Data is laid out on the array as follows:
22TB - BluRay Rips (~25-50GB Each)
1TB - 100MB Files
3TB - 1GB Files
.5TB - 1MB Files
Misc - 10,000 Empty Folders
Once the data has completed copy, we pull one drive out of the array and let it rebuild. If all drives pass this, they are ok'd to be moved into production. [/quote
I don’t know of anything to “stress test” an HDD.
I also wouldn’t advise it if there were. All it is going to do is weaken the two components most likely to break: the motor or the arm.
The only thing I would advise is to check SMART stats and then maybe some benchmarking.
I'm sure you're aware of failure probably curves. Before all the time and effort to rip apart the drives (and void warranty on $360 worth of drives) ...and setup the NAS, I want to rule out early failures. I did find a program that will do a read/write test to the entire disk surface called "gsmartcontrol". Found a few others two. I'm going to thrash the shit out of these before they end up in my NAS
Simple HDD test tool. It will read / write on all possible sectors and once there is an error it will report.
Found a couple of options you can try out, both options require access to a Linux terminal.
Just read the title...
...hdds dont need burn in... nothing does really.
And read it...
waste of time dude. That idnt going to tell you or do squat. Plug it in and enjoy. Seriously.
He wanted to test the drives before shucking the drives from the enclosures, and voiding the warranty.
first post said he bought them and wants to put them in the enclosures?
Edit: I see now... still not much point though... but I get it.
Maybe Hard Drive Sentinel, that has a option to read \ write to the disk as a testing procedure. Can all so do random and how many times you want it run though.
The pro version allows you to do multiple disks at a time, i guess it starts doing all of them at the same time as i scanned many and multiple drives at the same time without the pro version.
If they fail show the sales rep this thread.
Your QNAP NAS has built in tests if I remember correctly. I know FreeNAS does
I have 6 8tb drives shucked from easystores and 0 issues. Just make sure it works (you can power on and access drive) and if so, shuck it! This stress test is a waste of time.
