- Mar 27, 2007
- 2,817 (0.42/day)
- louisiana
Processor | Intel Core i5-12400F - Core i5 12th Gen Alder Lake 6-Core 2.5 GHz LGA 1700 65W |
Motherboard | GIGABYTE B760M--DS3H LGA 1700 DDR4 |
Cooling | CPU - Thermalright Assassin King 120 SE / Case - cooler master 120mm rear case fan (Air cooling) |
Memory | CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) |
Video Card(s) | GTX1060 6GB |
Storage | Samsung 1 TB 870 EVO SSD Main Drive / Samsung 500 GB 870 EVO SSD Backup Drive |
Display(s) | ASUS 23" LED Monitor |
Case | COOLER MASTER Centurion 5 (silver & black) |
Power Supply | CORSAIR RM-750X 750W Modular ATX |
Software | Windows 11 Pro 64bit Edition |
i just replaced my mb with MSI PM8M-V and installed the MSI "PC ALERT 4" v4.1.2.4hardware monitor. i have p4 3.4ghz 800fsb with 2gb pc3200 ddr400 ram and 300gb hdd, geforce 7600gs 512mb video card, 400watt PSU with one 12v rail. i didn't change any settings or overclock anything.
every few days the 12v voltages show up as 1.86v and the alarm goes off. i check voltage and read 12.16v at the board on the cpu 4 pin plug as well as the drive plugs while at the same time the hardware monitor shows 1.86v so i know the monitor is in error.
restarting the computer usually fixes this issue for a day or two. on a few occassions i had to uninstall and reinstall the hardware monitor to fix the issue.
i just tried using "Hardware Monitor 5" and it also showed 1.86v on the 12v leg but when i uninstalled "Hardware Monitor 5" "pc alert 4" nows reads 12.16v the same as my volt meter continues to read.
as far as i can tell i have the latest drivers installed, i'm using VIA HyperionPro Driver Package v 5.11A, VIA_AC97_Audio_Driver_v3.98A, and VIA VT8237 Ethernet Lan Driver v4.3
how can i get rid of this gremlin sending false readings?
