Hardware regretted buying
2,452 (1.17/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
Any hardware that you have purchased and regretted buying?
Doesn't matter if it is new or second hand..
I bought steel series arctis pro wireless.... at that time it was okay but now looking back i've spent way too much for these...
44,274 (6.80/day)
Asus P4S8X (buggy as hell mobo)
Logitech G500 (2x, broke in less than a year).
NF2 (no AGP driver support for Vista or newer)
IBM DeskStar (Hitachi was way Better)
Sony CDRW drive (Caused slow boot on my Athlon XP Rig (Removed and problem was fixed)
Rambus P4 mobo
A Seagate Hybrid SSHD 2.5 (Head parked and no way to turn that function off-would cause Game Lag) Replaced by Velociraptor.
Count von Schwalbe
Nocturnus Moderatus
3,445 (2.73/day)
Knoxville, TN, USA
Ryzen 5 3600, right after the 5600x came out. For $300, as I thought the AMD CPU shortage would be as bad as the GPU shortage. Fortunately, I managed to sell that system and get a 5600X.
1,457 (0.34/day)
Australia
Socket 1156 system, should have gone with AMD at the time... 8 threads (i7) for gaming back then was useless, 6 cores (Phenom II X6 ) would have been it!
825 (0.42/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
Probably my RTX3070, not that the card is bad, buy the prices dropped a lot a month after my purchase.
I could literally buy a 3080 at the same price a month after the purchase.
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
My socket AM3+ Asus board. Died in three months and the support turned me off from them for six years.
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
low end routers and mice coz of curious only
some good some bad but i don't feel it can meet my expectation, now most just sitting back in the boxes
6,431 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Creative Fatal1ty headset. Bought it in store after my $15 Philips SHP2500 headphones died after something like 5 years of service. All the reviews, even customer ones were praising it. They sounded like wet farts, since it was in store purchase I couldn't return them (even 1 hour after purchase). Sold them the next day to some local guy for something like $10 below the retail price.
1,978 (1.36/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
Powercolor RX 580 8GB. Overall RX 580 is pretty good, but what Powercolor did to it is asinine. Fan control is all fucked up. It needs 3000-3500 rpm stock, because Powercolor thinks that it's not okay for your card to reach temperatures higher than 70C. It sounds like fucken jet. Even at like 66C it reaches 2200 rpm, which is very excessive. I have been trying to tweak it both in wattman or by modifying vBIOS, but nothing changes that fucked up fan behaviour. Fuck PowerColor.
13,953 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
(1) A Creative Labs Sound Blaster sound card I regretted buying years ago - because once connected, I realized (A) the drivers sucked and (B) the on-board sound was just as good through my THX certified, self powered surround sound speakers. I should have gone with my original, but more expensive choice, the M-Audio Revolution 5.1, which I ended up buying (and appreciating) anyway. Lesson learned: Do better homework before buying and stop being a tightwad.
(2) A $12 RJ-45 Ethernet connector crimping tool - a piece of junk. Lesson learned: Don't buy junk tools and stop being a tightwad.
(3) A $24 RJ-45 Ethernet connector crimping tool - a more expensive piece of junk. Lesson learned: More expensive junk tools are still junk. To save money in the long run, buy quality tools from the start. And stop being a tightwad.
(4) Two Corsair Carbide 300r cases - quality design, inconsistent manufacturing techniques and poor and inconsistent quality assurance (QA). One case still had rough, unfinished edges on the sheet metal resulting in shredded and bloody knuckles. Both cases were un-"true". That is, they did not have exactly 90° bends in the sheet metal. This resulted in the cases sitting on only 3 of their 4 feet allowing them to wobble. It also meant the side panels were extremely difficult to remove and replace due to improper fit. Note two other identical 300r cases were just fine (hence the inconsistent QA complaint). Lesson learned: Don't assume a company known for making quality power supplies also makes other products of similar quality. (Note: this was before Corsair changed PSU OEMs).
(5) Acoustic Research Outdoor Bluetooth Speaker - For $28 I was NOT in any way expecting anything close to high fidelity audio. I just wanted something a little better than the 40 year old Realistic (yes, from Radio Shack) mini "boom box" I had out in my shed for when I was putzing around the yard. I do not like wearing earbuds when all sweaty and grimy. I figured with the AR brand on it, even at that price, it could not be that bad. I was wrong. I have heard 60 year old "transistor AM radios" sound better. Lesson learned: Hire someone else to do the yard work.
9,828 (3.40/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Not me personally but a friend came over one day and demanded we go get him a GPU. We picked up a Power color 6600 for $600 Canadian dollars. 2 Months later and the same card is $429. The kicker when I went to his house to install I had a hunch and brought a monitor. Sure enough the last time the PC has been turned on was using DP and for some reason the card needed to have the DP input active to show the screen so he did not even have to buy a new GPU. Granted the 6600 is much faster than the 570 but he only uses a 50" 60HZ TV so for me it was a very regrettable purchase advisement.
Actually I have a recent one. Asus Xonar AE sound card. I thought it still held true that a dedicated sound card was better than on board but 1220 blows it away. $99 down the drain basically.
1,964 (0.40/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard Womier SK75 (Green) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
SteelSeries Arctis 7 way back in like 2016/17 iirc. Truly terrible audio quality for the price (both playback and mic). Tried to use it for a couple of weeks but gave up.
Google Pixel 4. A buggy mess topped off with a rubbish battery. It was so bad that I dumped Android as a whole and bought my first iPhone.
Rode NT-USB microphone. Nothing bad with it at all, sounds great actually. However I never use it :( and I've had it for 5-6 years.
Beko Automatic (bean-to-cup) Coffee Machine - this still counts as tech yes? Yes convenient to make a coffee but jebus, was it difficult to clean out the inside. They claimed that the inside only needed to be cleaned during the descaling process once every 2-3 months when really the internal brewer needed cleaning at least 1-2 times/week. I accidentally broke an o-ring inside it while cleaning it one day and the next time I used it, I flooded my kitchen bench of the new apartment I moved into. Changed it to a Sunbeam Barista Max semi-automatic espresso machine (essentially a poorman's Breville/Sage Barista Express). Super impressed with the replacement and easy to clean + makes a better coffee.
12,172 (1.71/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
I regret paying launch day pricing for my X1800XT, hated my P4 prescott, but some of the cheaper AMD boards at the time had issues.
Original 775 socket coolers were garbage, I killed a board trying to push the pin in and the hole wasn't perfect and it cracked, Intel board too.
My Canon HG20, it was too expensive for the piss poor battery life you got and the flimsy build quality made me stop using it. At the time MKV files were hard to process as well, but the quality of video and audio was nice.
3,076 (0.82/day)
A second hand gtx 970 I got. Dit not look after for warning signs. First after I came home I see that cooler has been removed and when I put it in my pc. No signal and fans dead. I had just got a 100 % dead card that owner tried to repair him self but couldn't and Dit not tell me anything about it.
I had a good fight with him over returning the card and money back. First when I involved police I got my money back. So it ended well, but deffently and litterly an instant regret byeing it.
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Loads of stuff for one an itx motherboard, just not enough pciex slots.
Two PSU this year and a whole 5600G based pc I have NO use for.
I've since banned myself from buying.
Still , not as bad or expensive as some motoring fups though.
1,264 (0.20/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
Razer Deathadder mini. Gave it to my son for his chromebook
3,086 (0.53/day)
MN
System Name Personal / HTPC
Case Titan Silent 2 / CM HAF XB Evo
GeForce FX 5500 - enough said.
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
I probably don't buy as much hardware as most here so it improves my odds of avoiding bad experiences but there definitely was one. Back in 2000 before I started building my own rigs I bought an eMachines PC that came with Windows ME. It qualifies as my worst hardware choice and worst software choice all rolled into one. I returned the garbage before the 30 days was up.
734 (0.16/day)
Malaysia
System Name Cypher-C4
Processor Ryzen 9 5900X
Motherboard MSI B450 Tomahawk Max
Cooling Deepcool AK620
Memory 32GB Crucial Ballistix Elite 3200MHz
Video Card(s) Palit RTX 3060 Ti Dual
Storage 250GB Crucial MX500 + 2TB Crucial MX500 + 2TB WD Black + 4TB Toshiba + 1TB Samsung F3
Display(s) Acer XV272UP
Case Corsair Obsidian 750D
Audio Device(s) Behringher UMC202HD Audio Interface + Mackie HM-4 + Sennheiser HD 280 Pro + Shure SM58
Power Supply Corsair HX750i
Mouse Steelseries Rival 310
Keyboard Keychron K8 + Kailh BOX Crystal Jade switches + Ducky Good in Blue keycaps
There was a Logitech G400S mouse that I wasn't too fond of, and I ended up giving it away. It wasn't junk, but I wasn't comfortable using it.
Some cheap/junk headsets here and there.
Nothing tops this Seagate HDD though, which I bought in 2012/2013. No wonder it only had a 1-year warranty. Mine lasted about 18 months IIRC.
315 (0.21/day)
System Name Back in Black
Processor Ryzen 7 5700X
Motherboard MSI B550 Tomahawk Max WIFI
Cooling ID-Cooling SE-224-XT Black
Memory ADATA XPG 16GB (2x8) 3200mhz C16
Video Card(s) XFX RX 6700 XT Speedster Merc 319 _larry Edition
Storage Solidigm P41 Plus 1TB / Crucial MX500 500GB
Display(s) Samsung 32" TV 1080p
Case Montech Air X Black
Power Supply Thermaltake Toughpower GF1 750W Gold
Mouse Redragon M711 Cobra
Several ASRock and Biostar motherboards for very tight budget for people that didn't want to get better stuff. The "I told you so" was part of the end deal, and I've avoided them like the plague ever since.
9,340 (4.93/day)
Louisiana
Keyboard G710+x3
7900x you know the pigeon poop inside line :laugh:
Had some fun with it but this opened hells gate of garbage asus x299 boards mostly prime deluxe I went through 3 of these suckers before I gave up and got instore credit and bought a used x299 apex off ebay for a fraction of the money.
Also ek pe280 water loop kits which came with defective ek cryocrap fluid and garbage acetal pump reservoir combos.
freeagent
10,388 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
D9GMH.. they all died :D
Maybe my Revo Drive, that died too.
EVGA 680i.. couldn’t run my Q6600 at stock or overclocked..
Corsair TX-850, that died too.
A64 4200 dual core, wasn’t a good clocker ended up losing two boards trying to clock it.. that was the weekend I moved to Intel and didn’t look back until Zen 3 :D
Frick
Fishfaced Nincompoop
20,060 (2.87/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
What was wrong with them? I've basically only bought the cheapest motherboards I could find (with the correct chipsets), and I have very rarely seen issues with store bought motherboards.
