Having an issue with latency/audio dropouts stutter on my new pc not sure what is causing it
Mattyblueeyes
5 (0.01/day)
So ive just built a new PC and i was checking latency through latency mon when i have having these spikes when just running it idle after booting my PC. Ive got a i9 13900k and a 4090 z970-f gaming wifi MB what would be causing this kind of spikes as im not that familiar with latency mon and i cant work it out.
CONCLUSION
_________________________________________________________________________________________________________
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:05:01 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: MATTYBLUEEYES
OS version: Windows 11, 10.0, version 2009, build: 22621 (x64)
Hardware: Intel Z790 Ddr5, PCSpecialist
BIOS: 0813
CPU: GenuineIntel 13th Gen Intel(R) Core(TM) i9-13900K
Logical processors: 32
Processor groups: 1
Processor group size: 32
RAM: 32508 MB total
CPU SPEED
Reported CPU speed (WMI): 30 MHz
Reported CPU speed (registry): 2995 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 14529.80
Average measured interrupt to process latency (µs): 5.359342
Highest measured interrupt to DPC latency (µs): 633.0
Average measured interrupt to DPC latency (µs): 1.045420
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 162.351920
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.003676
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.003742
ISR count (execution time <250 µs): 34243
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 341.242070
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 528.49 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.002666
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 528.49 , NVIDIA Corporation
Total time spent in DPCs (%) 0.006452
DPC count (execution time <250 µs): 115762
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 1
DPC count (execution time 1000-2000 µs): 0
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: hwinfo64.exe
Total number of hard pagefaults 2752
Hard pagefault count of hardest hit process: 1328
Number of processes hit: 27
PER CPU DATA
CPU 0 Interrupt cycle time (s): 30.337816
CPU 0 ISR highest execution time (µs): 24.902170
CPU 0 ISR total execution time (s): 0.002507
CPU 0 ISR count: 6775
CPU 0 DPC highest execution time (µs): 134.020701
CPU 0 DPC total execution time (s): 0.144462
CPU 0 DPC count: 34162
CPU 1 Interrupt cycle time (s): 16.309001
CPU 1 ISR highest execution time (µs): 146.329883
CPU 1 ISR total execution time (s): 0.026804
CPU 1 ISR count: 1465
CPU 1 DPC highest execution time (µs): 140.759265
CPU 1 DPC total execution time (s): 0.022523
CPU 1 DPC count: 2949
CPU 2 Interrupt cycle time (s): 15.587627
CPU 2 ISR highest execution time (µs): 131.584641
CPU 2 ISR total execution time (s): 0.248326
CPU 2 ISR count: 16025
CPU 2 DPC highest execution time (µs): 159.374290
CPU 2 DPC total execution time (s): 0.226976
CPU 2 DPC count: 30228
CPU 3 Interrupt cycle time (s): 13.542445
CPU 3 ISR highest execution time (µs): 1.043072
CPU 3 ISR total execution time (s): 0.000007
CPU 3 ISR count: 25
CPU 3 DPC highest execution time (µs): 16.302504
CPU 3 DPC total execution time (s): 0.000141
CPU 3 DPC count: 26
CPU 4 Interrupt cycle time (s): 10.487325
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 36.980968
CPU 4 DPC total execution time (s): 0.001092
CPU 4 DPC count: 453
CPU 5 Interrupt cycle time (s): 10.712831
CPU 5 ISR highest execution time (µs): 63.957930
CPU 5 ISR total execution time (s): 0.000303
CPU 5 ISR count: 12
CPU 5 DPC highest execution time (µs): 31.436394
CPU 5 DPC total execution time (s): 0.000253
CPU 5 DPC count: 39
CPU 6 Interrupt cycle time (s): 9.048180
CPU 6 ISR highest execution time (µs): 162.351920
CPU 6 ISR total execution time (s): 0.009180
CPU 6 ISR count: 552
CPU 6 DPC highest execution time (µs): 341.242070
CPU 6 DPC total execution time (s): 0.009355
CPU 6 DPC count: 1377
CPU 7 Interrupt cycle time (s): 8.847223
CPU 7 ISR highest execution time (µs): 1.975292
CPU 7 ISR total execution time (s): 0.000003
CPU 7 ISR count: 2
CPU 7 DPC highest execution time (µs): 23.507846
CPU 7 DPC total execution time (s): 0.000336
CPU 7 DPC count: 113
CPU 8 Interrupt cycle time (s): 8.297833
CPU 8 ISR highest execution time (µs): 3.246077
CPU 8 ISR total execution time (s): 0.001101
CPU 8 ISR count: 2601
CPU 8 DPC highest execution time (µs): 128.521536
CPU 8 DPC total execution time (s): 0.051620
CPU 8 DPC count: 18475
CPU 9 Interrupt cycle time (s): 12.346693
CPU 9 ISR highest execution time (µs): 125.642070
CPU 9 ISR total execution time (s): 0.012643
CPU 9 ISR count: 700
CPU 9 DPC highest execution time (µs): 118.755259
CPU 9 DPC total execution time (s): 0.020591
CPU 9 DPC count: 3241
CPU 10 Interrupt cycle time (s): 12.697830
CPU 10 ISR highest execution time (µs): 124.959599
CPU 10 ISR total execution time (s): 0.059262
CPU 10 ISR count: 4511
CPU 10 DPC highest execution time (µs): 152.888815
CPU 10 DPC total execution time (s): 0.100345
CPU 10 DPC count: 16575
CPU 11 Interrupt cycle time (s): 14.823070
CPU 11 ISR highest execution time (µs): 2.547579
CPU 11 ISR total execution time (s): 0.000572
CPU 11 ISR count: 1565
CPU 11 DPC highest execution time (µs): 146.899499
CPU 11 DPC total execution time (s): 0.030309
CPU 11 DPC count: 4706
CPU 12 Interrupt cycle time (s): 8.526302
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 45.130551
CPU 12 DPC total execution time (s): 0.002826
CPU 12 DPC count: 811
CPU 13 Interrupt cycle time (s): 8.482766
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 31.888481
CPU 13 DPC total execution time (s): 0.000148
CPU 13 DPC count: 50
CPU 14 Interrupt cycle time (s): 8.431070
CPU 14 ISR highest execution time (µs): 45.288815
CPU 14 ISR total execution time (s): 0.000250
CPU 14 ISR count: 10
CPU 14 DPC highest execution time (µs): 96.038731
CPU 14 DPC total execution time (s): 0.004335
CPU 14 DPC count: 768
CPU 15 Interrupt cycle time (s): 8.380670
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 9.134558
CPU 15 DPC total execution time (s): 0.000025
CPU 15 DPC count: 9
CPU 16 Interrupt cycle time (s): 2.101843
CPU 16 ISR highest execution time (µs): 0.0
CPU 16 ISR total execution time (s): 0.0
CPU 16 ISR count: 0
CPU 16 DPC highest execution time (µs): 83.527212
CPU 16 DPC total execution time (s): 0.002325
CPU 16 DPC count: 996
CPU 17 Interrupt cycle time (s): 1.765770
CPU 17 ISR highest execution time (µs): 0.0
CPU 17 ISR total execution time (s): 0.0
CPU 17 ISR count: 0
CPU 17 DPC highest execution time (µs): 3.622705
CPU 17 DPC total execution time (s): 0.000009
CPU 17 DPC count: 3
CPU 18 Interrupt cycle time (s): 1.177176
CPU 18 ISR highest execution time (µs): 0.0
CPU 18 ISR total execution time (s): 0.0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 0.0
CPU 18 DPC total execution time (s): 0.0
CPU 18 DPC count: 0
CPU 19 Interrupt cycle time (s): 0.796715
CPU 19 ISR highest execution time (µs): 0.0
CPU 19 ISR total execution time (s): 0.0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 5.857763
CPU 19 DPC total execution time (s): 0.000042
CPU 19 DPC count: 12
CPU 20 Interrupt cycle time (s): 1.948102
CPU 20 ISR highest execution time (µs): 0.0
CPU 20 ISR total execution time (s): 0.0
CPU 20 ISR count: 0
CPU 20 DPC highest execution time (µs): 89.206678
CPU 20 DPC total execution time (s): 0.001535
CPU 20 DPC count: 215
CPU 21 Interrupt cycle time (s): 1.684925
CPU 21 ISR highest execution time (µs): 0.0
CPU 21 ISR total execution time (s): 0.0
CPU 21 ISR count: 0
CPU 21 DPC highest execution time (µs): 41.133890
CPU 21 DPC total execution time (s): 0.000995
CPU 21 DPC count: 245
CPU 22 Interrupt cycle time (s): 1.220809
CPU 22 ISR highest execution time (µs): 0.0
CPU 22 ISR total execution time (s): 0.0
CPU 22 ISR count: 0
CPU 22 DPC highest execution time (µs): 33.711519
CPU 22 DPC total execution time (s): 0.000106
CPU 22 DPC count: 23
CPU 23 Interrupt cycle time (s): 0.774176
CPU 23 ISR highest execution time (µs): 0.0
CPU 23 ISR total execution time (s): 0.0
CPU 23 ISR count: 0
CPU 23 DPC highest execution time (µs): 4.755927
CPU 23 DPC total execution time (s): 0.000011
CPU 23 DPC count: 4
CPU 24 Interrupt cycle time (s): 1.792063
CPU 24 ISR highest execution time (µs): 0.0
CPU 24 ISR total execution time (s): 0.0
CPU 24 ISR count: 0
CPU 24 DPC highest execution time (µs): 49.278798
CPU 24 DPC total execution time (s): 0.00060
CPU 24 DPC count: 94
CPU 25 Interrupt cycle time (s): 1.392580
CPU 25 ISR highest execution time (µs): 0.0
CPU 25 ISR total execution time (s): 0.0
CPU 25 ISR count: 0
CPU 25 DPC highest execution time (µs): 36.283139
CPU 25 DPC total execution time (s): 0.000108
CPU 25 DPC count: 20
CPU 26 Interrupt cycle time (s): 1.018271
CPU 26 ISR highest execution time (µs): 0.0
CPU 26 ISR total execution time (s): 0.0
CPU 26 ISR count: 0
CPU 26 DPC highest execution time (µs): 66.765275
CPU 26 DPC total execution time (s): 0.000420
CPU 26 DPC count: 26
CPU 27 Interrupt cycle time (s): 0.627419
CPU 27 ISR highest execution time (µs): 0.0
CPU 27 ISR total execution time (s): 0.0
CPU 27 ISR count: 0
CPU 27 DPC highest execution time (µs): 4.486144
CPU 27 DPC total execution time (s): 0.000017
CPU 27 DPC count: 5
CPU 28 Interrupt cycle time (s): 1.665659
CPU 28 ISR highest execution time (µs): 0.0
CPU 28 ISR total execution time (s): 0.0
CPU 28 ISR count: 0
CPU 28 DPC highest execution time (µs): 42.450083
CPU 28 DPC total execution time (s): 0.000391
CPU 28 DPC count: 93
CPU 29 Interrupt cycle time (s): 1.335449
CPU 29 ISR highest execution time (µs): 0.0
CPU 29 ISR total execution time (s): 0.0
CPU 29 ISR count: 0
CPU 29 DPC highest execution time (µs): 49.252755
CPU 29 DPC total execution time (s): 0.000268
CPU 29 DPC count: 27
CPU 30 Interrupt cycle time (s): 0.936723
CPU 30 ISR highest execution time (µs): 0.0
CPU 30 ISR total execution time (s): 0.0
CPU 30 ISR count: 0
CPU 30 DPC highest execution time (µs): 39.834391
CPU 30 DPC total execution time (s): 0.000146
CPU 30 DPC count: 17
CPU 31 Interrupt cycle time (s): 0.611687
CPU 31 ISR highest execution time (µs): 0.0
CPU 31 ISR total execution time (s): 0.0
CPU 31 ISR count: 0
CPU 31 DPC highest execution time (µs): 3.167947
CPU 31 DPC total execution time (s): 0.000003
CPU 31 DPC count: 1
I understand the nvidia drivers are known to cause latency im more referring to the huge spike in highest measured interrupt to process latency. This is also with high power plan and max performance on graphics card. Any help is appreciated
And did you do as advised? Is your BIOS current? Is the OS current? Drivers?
How much RAM is installed?
As far as I know, NVIDIA (as an entire brand) is not susceptible to latency issues any more than AMD. My NVIDIA, for example, is showing all green in LatencyMon.
Well this is whats odd i just played COD MW2 and it was all green it only seems to happen when starting my pc that i get these huge latency spikes ive tested it a few times now in games or like 10 mins after starting and its all green and normal. Bios is updated 32gb ram windows 11 and drivers are all current/up to date unless there is some that im missing they arer up to date off my mb website which is a z790-f gaming wifi i9 13900k 4090. If you google about latency and nvidia drivers there are tons of people having latency issues with nvidia drivers so much so nvidia even noted it as an issue in one of the last drivers that came out. https://www.nvidia.com/en-us/geforc...orce-grd-52849-feedback-thread-released-2823/ - under open issues
I know there are issues NVIDIA. I am just saying if you google AMD drivers and latency, you will find many hits there too.
Frankly, I do not put a lot of stock in LatencyMon results - unless I can actually hear or see latency issues.
Have you tried any other programs, like DPC Latency Checker?
Disclaimer: While I have some experience with latency issues, I am NOT claiming any expertise in this area. All I can promise is that I will try not to lead you astray.
I am far from an expert in this area also I just appreciate you actually responding and trying to help I didn't mean to come across as rude i just misunderstood what you wrote, I have not tried any other programs yeah I mean it could just be a case of something loading upon boot that is randomly causing the spike cause it seems after about 5 mins of the pc being booted up everything is fine which seems odd I have seen a post about people with 12th and 13th gen on windows 11 having this issue that I was just reading. Does seem similar to the latency spikes i am getting but who knows. There is definitely not an issue when I'm playing games from what I can tell I just played MW2 and it ran completely smooth for quite some time latency mon was all green and low, the only game ive noticed spikes on latency mon and maybe some audio issues is rdr2 when playing the story so idk if that is just an issue to do with that game specifically.
Ive just used the bitsum highest performance power plan which comes with process lasso and the issue is completely gone im not getting any spikes at all on boot virtually. It disables core parking completely so im wondering if this is an issue with core parking in windows 11 or just with 12th and 13th gen cpus in general but yeah the issue seem to be completely gone i just ran it on boot and got 0 spikes above 150 and whats even more interesting is the nvidia driver doesn't seem to be spiking as high anymore either.
Last Nvidia driver's notes mentions this issue. Try rolling back to a previous driver. That being said it could just be different sound devices causing it. Go into your device manager and disable all sound devices you aren't using.
I have looked up latency mon but when was the last update for the utility ?
New system might not be all that compatible with it seeing even ddr5 doubles latency for 50% more frequency.
I have no idea tbh you could for sure be on to something but like i said for the most part when i run bitsum highest performance the spikes in latency mon go still getting them in rdr2 but seems like the only game its happening and the game runs smooth so idk why it is like that.
You should fill in your system spec's page and switch it to yes show system spec's
But example ddr4 quad channel on x299 runs around mid 40's at 4000ghz
And ddr5 say 6000ghz is hitting around low to mid 60 and is shown as quad because it's dual channel per stick.
But if your thinking 4090 is high latency wise IDK where to check that besides what you're already doing = game play.
AIDA64 can show latency as well which has a 30 day freebie period
Also check out some of the lastest post for simalar hardware as your own you might feel more at ease and or see some ddr5 timing tips :cool:
Just because an app has not been updated recently does not mean it cannot effectively do what it was designed to do. Latencies are all about time. And last I heard, 1 second still equals exactly 1000.0 milliseconds. So as long as the operating system supports running that app, and as long as there are no unresolved bugs that might affect the accurate counting of milliseconds, no big deal.
Installing nvidia drivers in MSI mode can help with DPC latency. Try it out with TPUs nvcleaninstall if you haven't yet.
