hd2900xt driver for ubuntu
cepoi
122 (0.02/day)
Processor Intel Core 2 Quad Q6600 G0 @ 2.7 (300x9)
Motherboard Abit AW9D-MAX (stupid board...with Q6600 G0 only get 300 fsb..)
Cooling Zalman 9500LED
Memory 2x1gb Corsair XMS2 DDR2-800 @ 950MHz (4-4-4-12)
Video Card(s) 2 x Asus HD2900XT 512MB DDR3 Crossfire @ 850/950
Storage 120gb maxtor sata2 + 160gb western digital sata2 + 200gb maxtor sata2
Display(s) Samsung SyncMaster 931BW 19" widescreen LCD
Power Supply Cooler Master Real Power Pro 850 watt
Software Microsoft Windows Vista Home Premium 32bit
does anyone knows where i can get it...or it does not exist??
Nope...
Wait about 6 months maybe if we are lucky...
Current drivers are fully supported through x1950 series.
support is now available for this ( with the 8.41 linux driver from ati. )
I have not had good luck with the driver. Composite, for me, had to be disabled, caused system hardlock. And performance is horrible, on a 2900XT 1GB UT2k4 isnt even playable, dipping into the teens in framerate. other than that....it works?
are you using any QT based apps? and on the performance... hmm... that can and does happen... UT2k4 probobly was not one of the games they tested with, have you tried Doom 3 or Quake 4 on your pc yet?
try ubuntu gusty gibbon tribe 4, its a beta, and they might have the driver integrated into those.
that explains it all... try it on the previous one, Feisty.... should work better, and also try disabling the compositing engine.
i suggested gusty cause i believe feisty was out before the 2900, so if the drivers were to be integrated, wouldn't they integrated them into gusty?
