HD6xxx Series BIOS Flash
Random Murderer
The Anti-Midas
6,974 (1.04/day)
Florida, A.K.A. the Sweatbox
System Name TOO MUCH RADIATOR! | The TV Box a.k.a. The Shoebox
Processor Core i7 4930K @ 4.5GHz | Core i5 6600K @ 4.5GHz
Motherboard Asus X79 Rampage IV Extreme | Asus Z170i Pro Gaming
Cooling Custom water on CPU and GPU, dual 360mm radiators | Corsair H80i
Memory 4x 8GB G.Skill TridentX DDR3-1600 | 2x 4GB G.Skill RipJaws 4 DDR4-3000
Video Card(s) Sapphire AMD R9 295x2 | PowerColor AMD HD7970
Storage Samsung SSD 830 256GB, various others | 2x 1TB Seagate Barracudas in RAID1
Display(s) Dell U2713HM 2560x1440 IPS | Panasonic TC-L32E5 1080p IPS TV
Case Thermaltake Suppressor F51 (stripped down to hold two radiators) | Cooler Master Elite 130
Audio Device(s) RM-DAC -> Xiang Sheng 708b -> Sennheiser HD650 | HDMI sound device on 7970
Power Supply LEPA G1600-MA 1600W | Corsair CX750M 750W
Software Win 10 64
Benchmark Scores over 9000 BungholioMarks, "Bitchin' Fast"
People are talking of flashing their 68xx and 69xx cards, so where is the program to do so? Winflash 2.0.1.13 tells me "Critical file missing," and ATiFlash 3.79 doesn't support 6 series cards. I saw a post where someone said to use ATiFlash 3.83, but for the life of me can't find it.
Any help would be appreciated, and thanks in advance!
Linkey
As of now it is only 6950s that unlock to 6970s. There is no unlocking of 6850s/6870s.
you need a 6950 then that will unlock to a 6970...
for u current card u've reached its safe limits dude, nice over clock btw! (byte 6850 doesnt unlock to 6870, u just got to OC it past 6870 levels, i no its confusing but as i no of now, the 6850 doesnt come with the extra stream processors the 6950)
Linkey
Wasn't looking to unlock anything, i just prefer a BIOS flash over running a program to keep my card oc'd.
However, i do have a BIOS with 1120 sp for the 6850 and did want to play around a bit.
Thanks for the replies.
Edit: That link contains a download for winflash 2.0.1.13, which I've already tried with no luck.
You CAN do that. The bios file can be modified to run different clocks I used to have my ATI 9800 set with a custom bios but I have not since, hopefully someone else can walk you through it.
I know I can, in fact there's a BIOS I modded, on my desktop, ready to be flashed. The BIOS itself is not the problem, it's how to flash to an HD6xxx card.
Winflash 2.0.1.13 is now running without the aforementioned error, but it's reporting my card as a 4800 series. It seems driver sweeper didn't do as thorough of a job as it should have when I upgraded from my twin 4870s to this. CCC, HWMonitor, TriXX, GPU-z, and CPU-z all report the correct card, but CCleaner and now Winflash still see "ATi Radeon 4800 Series."
Can you do it right from a Dos Prompt like we did in the old days?
Never tried. Winflash has done me right since my 9600 back in the day. This is the first issue I've ever experienced problems with it.
I know ATiFlash is a DOS program and I'm willing to use it, but the latest version I can find is 3.79, which doesn't support 6xxx cards. 3.83 supposedly supports them, but the only two links I could dig up for it were in Russian, and their trustworthiness is in question...
EDIT: It seems the cause of some programs showing the 4800 is a registry value in conjunction with said programs reading the registry value instead of the hardware itself. Winflash 2.0.1.13 is now working thanks to tinkering with compatibility mode(don't ask me to reproduce it, somehow the original settings are now working) and has provided successful flashes to my 6850 twice now, once through itself and once through RBE 1.26(which says Winflash is reporting a BARTS core with the correct hardware id). thanks for all your help.
I forgot about RBE that tool is a godsend. I am glad it worked out!
