HDD power consumption question.
Polarman
1,626 (0.26/day)
Rimouski
System Name Polar's Dragon
Processor AMD Phenom II 975BE
Motherboard MSI 890FXA-GD65 (Bios 18.7)
Cooling Zalman CNPS 9700 Led
Memory Gskill 8GB DDR3-1333 (8,8,8,21)
Video Card(s) MSI HD6870 Hawk
Storage WD Raptor 250 - WD RE4 500GB
Display(s) Samsung T240 (1920 X1200)
Case Silverstone Raven 2
Power Supply PC Power&Cooling Silencer 750 (Red)
Software Windows 7 Home Premium 64Bit + SP1
I recently changed my 3 hard drives combo to just one. Purchased a WD Black 640GB as replacement.
I went on two power calculting website to figure out how much power i would save in getting rid of 2 hard drives. Both sites gave me a result of 50 watts in savings.
I don't really know if this is true or not. 25 watts per drive seems pretty darn high.
Anyway, i'm pretty sure that i'll comsume less energy with only one hard drive.
2,792 (0.38/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
50W?
BS.
Just look up the sticker on your HDD; there will be absolute maximum amperage ratings for 12V and 5V that the drive feeds on. For example my Samsung F1 640GB is rated 0.7A @ 12V and 0.5A @ 5V. That's maximum power draw of 13.8W. In reality the drive gets anywhere near that figure only during spin-up. Idle consumption should be ~5W or so, load read/write would be 1-2W more.
1,258 (0.20/day)
North Carolina
Check here for some power measurements of some fairly common drives. On average a 7200rpm drive uses about 7-8W idle and 9-12W when seeking heavily.
The hdd label is a good source of info on its power consumption. However, I don't that that's the absolute maximum. I think the power supply calulator is correct. It its taking into consideration the startup current. When a hdd starts up, it draws a considerable amount of power (~20+W). But it's only for a fraction of a second. So if you were measuring power consumption, you wouldn't see a 50W drop, more than likely only around 15-18W on idle.
