HDMI not working after bios update
ibrahimrt27
13 (0.05/day)
Hello, sorry for the spelling mistakes. I write using translation.
I have 12 Powercolor AXRX 570 8GBD5-DHDV3 graphics cards. Since these floors were used in mining before, I do not have the original bios. Vram samsung k4g80325fc. I have installed about 5-6 bios available on the site, but I cannot get an image from HDMI, only Displayport gives an image. When I install the old bios used in mining, HDMI works. I'm waiting for your help, thank you
Gpu-z screenshot please
Which bioses did you try? Did you also try the validated bios?
I am attaching the GPU-Z screenshot showing the model of the card and the bios I tried. My card only has 1XHDMI, 1x DP and 1x DVI output. In the original ROM transfer on the forum, only Displayport and DVI ports work. Also, on the Powercolor website, it says that my card has an 8-pin power input, but the card I have has a 6-pin power input.
Can you make a picture of the PCB?
Place the old bios back in
Get a screenshot from that, also include a screenshot from the advanced tab with memory info-click the V and find it.
On the main gpu z screen hit the black arrow next to the uefi check box and attempt to upload the bios to the vga bios collection/database.
You might get a prompt stating bios is already in the collection with a link copy and paste that link here.
While youre at it do what @VuurVOS wrote, also get a pic of the white sticker on the card and a pic of the metal frame with numbers surrounding the gpu die and a pic of a ram chip please.
I hope I followed your instructions correctly. Also, why are the 2 vrams I mentioned with the blue line different from the others?
Because from the manufacture they encode the files to sometimes support only 1, or more ram types with timing tables.
However people modify the files etc and yeah 1900 is not a stock speed
This is your card specifically per sticker.
1168 is base, 1250 is the oc i believe and 1750 is your ram
Try the bios he suggested
I looked in unverified and the only bios that matches is what @VuurVOS provided which is a verified bios
Bu, sticker'a göre özel olarak sizin kartınızdır.
1268 temel, 1250 oc sanırım ve 1750 de ram'iniz
Önerdiği bios'u deneyin
Doğrulanmamış olana baktım ve eşleşen tek bios, @VuurVOS tarafından sağlanan doğrulanmış bios'tur
@VuurVOS
Önerilen BIOS'u denediğimde
HDMI çalışmıyor, muhtemelen bu bios diğer ekran kartının bios'udur, o kartta 1x DVI, 1x HDMI ve 3x Displayport çıkışı var. Ekran kartımda her porttan 1 tane var. Muhtemelen bu yüzden olmuyor. Eski bios'ta tüm çıkışlar çalışıyordu ama code 43 hatası veriyordu. O bios'un bellek hızlarını normale döndürsek çözüm olabilir mi?
@VuurVOS
Please translate
@VuurVOS
When I tried the recommended BIOS HDMI is not working, probably this bios is the bios of the other video card, that card has 1x DVI, 1x HDMI and 3x Displayport output. There is 1 of each port on my graphics card. That's probably why it's not happening. In the old bios, all outputs were working, but it was giving code 43 error. Could it be a solution if we reset the memory speeds of that bios to normal?
It could be the bios has a fucked up signature. Can you share that bios here?
I see you already shared a screenshot of GPU-Z Advanced tab. That bios has a screwed signature since it is not running at stock speeds.
Please flash this bios instead. It also matches the part number on the PCB:
Please translate
Sorry
When I tried the bios suggested
HDMI is not working, probably this bios is the bios of the other video card, that card has 1x DVI, 1x HDMI and 3x Displayport output. There is 1 of each port on my graphics card. That's probably why it doesn't happen. In the old bios, all outputs were working, but it was giving code 43 error. Could it be a solution if we reset the memory speeds of that bios to normal?
I installed the bios you suggested, the result is the same, code 43 error.
Tomorrow I will upload it to different graphics cards and let you know.
You need to make sure the ram is physically present as to what is in the bios, you cannot use samsung fc on a fb, fe fd card, or hynix etc
I tried this bios on 3 different graphics cards, the result is the same, also in the description it says that it is a mining bios, gpu-z shows the clock speeds as 0 mhz.
How many cards are you trying to flash at once?
Someone fucked up that bios for mining...
When I just installed the amd/ati pixel clock patcher patch, the clock speeds returned to normal and the code 43 error disappeared. Will this procedure I do be permanent?
NO. AMD/ATI Pixel clock patcher is a workaround for the current Windows Installation. When using AMD/ATI Pixel clock patcher it removes the bios signature check
Can you try the following bioses?
