Morgoth
Fueled by Sapphire
- Aug 4, 2007
- 4,254 (0.65/day)
- Netherlands
System Name | Wopr "War Operation Plan Response" |
Processor | 5900x ryzen 9 12 cores 24 threads |
Motherboard | aorus x570 pro |
Cooling | air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick |
Memory | kingston 32gb ddr4 3200mhz ecc 2x16gb |
Video Card(s) | sapphire RX 6950 xt Nitro+ 16gb |
Storage | 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI |
Display(s) | AOC display 1080p |
Case | SilverStone SST-CS380 V2 |
Audio Device(s) | Onboard |
Power Supply | Corsair 850MX watt |
Mouse | corsair gaming mouse |
Keyboard | Microsoft brand |
Software | Windows 10 pro 64bit, Luxion Keyshot 7, fusion 360, steam |
Benchmark Scores | timespy 19 104 |
ok i got a aorus x570 pro mainboard and a bunc of noctua fans..
and im using Smart fan 5 (AORUS system information viewer) to controll them
my first issue was that my 3000 rpm noctua fan doest want to do what i tell it do trough that program.. like ramping up to 2500 rpm... it wont do it its realy stubborn..
i had it connected to one of the mainboard fan headers. so i try switching it.. i had 2 more fan headers that whernt pluged in they where gaving me the same issue
i can run the fan by connecting it straight to the psu... but if i use noctua low noise adapter.. it wont run... why do them even add it with it ???
and when i plug my other 1800rpm fan to system fan 1 header... geus what it wont run.. dont know why even telling to go to full speed doest do it...
tough cpu and front intake are connected to the mainboard and they do the things i tell them to do...that works fine
running the 3k rpm fan constaly makes allot of noise.... so not an option to hot wire it into the psu...
so im thinking to use one of these am i missing something??
