Heat sink not in contact with GPU chip...
  • Thread starter Deleted member 110753
  • Start date
Hi Guys,
Replacing the thermal paste of an old Gigabyte video card, I've seen for the first time the heat sink not in contact with the GPU chip.
There is about 2 or 3/10 mm of difference which requires a lot of thermal paste.
Do you think it's a mistake of design/manufacturing?
Have I to modify the thickness of 4 nuts ?
7,412 (2.63/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
you mean 0.2 mm or 2mm ?
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
what card out of curiosity?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
curious how that gap was measured.
1,703 (0.25/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k Delided
Motherboard Gigabyte Z390 Master
Cooling 420mm Custom Loop
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 1TB SX8200, 250GB 850 EVO, 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
Perhaps the original thermal paste was very viscous and set up before the cooler had a chance to settle down onto it. They are held in place by the pressure of the springs under the mounting nuts.
You could reapply some paste while the card is still a bit warm. Or you could put the paste tube in a plastic bag, and then let it sit in some warm water before applying.
If it were me, I'd just forget everything I said, reapply some new paste and enjoy your better temps.
dorsetknob
9,106 (1.24/day)
The pattern spread of the old Tim on both cooler and GPU would be interesting to look at that is if you have not cleaned both yet
any chance of a photo ?
7,412 (2.63/day)
Poland
Cooling Noctua D15S
0.2-0.3 mm of thermal paste between the die and the heatsink is very good. 2-3 mm means you have to tighten the screws or maybe reseat the cooler again, slowly and carefully.
How do you measure 0.2mm between the die and heatsink I wonder. 2 mm may be visible with a magnifying glass but not 0.2mm.
AsRock
TPU addict
19,251 (2.95/day)
UK\USA
Cooling D15
Maybe it has incurrect spacers or it's been bent, maybe your tightening the screws wrong. A few picture's would help.
372 (0.06/day)
Where the beer is good
System Name Karl Arsch v. u. z. Abgewischt
Processor i5 3770K @5GHz delided
Motherboard ASRock Z77 Professional
Cooling Arctic Liquid Freezer 240
Memory 4x 4GB 1866 MHz DDR3
Video Card(s) GTX 970
Storage Samsung 830 - 512GB; 2x 2TB WD Blue
Display(s) Samsung T240 1920x1200
Case Bitfenix Shinobie XL
Power Supply Cougar G600
Mouse Logitech G500
Keyboard CMStorm Ultimate QuickFire (CherryMX Brown)
Software Win7 Pro 64bit
Sometimes the screws arn't pulled tight enough coming from the factory. Reapply paste and remount the cooler, afterward check again if there is proper contact.
The measure 0.3mm comes from my eyes, I mean when I put the heatsink on the card, the 4 nuts are in contact but not the gpu.
Like my other cards (GTX 660, 650, 550), this Gigabyte GT 440 uses 4 coil spring screws, but when tightened there is no contact with the chip.
Since I put the new thermal paste (Artic Silver 5), the temperature increases (resp.decreases) quickly when I stress (resp. stop stress) the GPU.
From my experience, the thickness of nuts is wrong and requires I use my belt sander (if there is not an electrical problem to put the heat sink in contact with the chip)...
5,678 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
When the paste is applied in the factory they use a mask and it's usually quite thick around 1mm but when you replace that paste because it's old you need to make it the same level of thickness as done in the factory
7,412 (2.63/day)
Poland
Cooling Noctua D15S
Let me speel this out loud and clear, you can see a third of one millimeter ?
Well if that's the case then thermal paste will fill that gap.
dorsetknob
9,106 (1.24/day)
How thick is a piece of human hair?
Europeans consider hair with a diameter of 0.04 to 0.06 mm as thin, hair with a diameter between 0.06 and 0.08 mm as normal, and hair with a diameter between 0.08 and 0.1 mm as thick. By comparison with European hair, Asian hair is significantly thicker. The average diameter of Asian hair is 0.08 to 0.12 mm.
clamp a hair between the die and cooler :) then see if you can pull it out without breaking the hair
PS i can see individual hairs and you ??? i bet your wife/girlfriend would spot a thin blonde hair on you at 10 paces especialy if she is Dark haired:).
There is no problem to fill the gap with thermal paste.
The only problem is the 4 coil spring of screws are useless if there is no contact with GPU.
Consequently, the nut thickness seems wrong...
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
I had it my WF3 7970m the problem was that the outer holding frame was bent and way too soft. I've put a copper shim on the GPU die.
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
There should be no problem with the die contacting the HS, that's what it's supposed to do, just make sure nothing else touches it. So the retaining nuts are keeping the HS too high? Maybe installed wrong?
dorsetknob
9,106 (1.24/day)
you may put a shim washer under the Spring's.............see PS
If you have no access to coppershim material aluminium baking foil is a good substute
and of course the PS
ps
BE Careful not to over tighten the Screws after shimming.
44,273 (6.80/day)
Ok 1 you are using Arctic Silver 5 which requires a baking time to reach maximum performance.
If you are so concerned about this take the heatsink off, get plastic washers and some Akasa Shinetsu Thermalpads, stack them up together (they fuse together) and be done with it. PS stress Testing is not needed. Play games
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Ive modified heat sinks to fit tighter in the past. If you think it needs it do it
44,273 (6.80/day)
Yeah aslong as he doesnt crush the die lol
12,340 (2.21/day)
Oregon
44,273 (6.80/day)
peche
Thermaltake fanboy
6,709 (1.75/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
This....
tell moar about the video card dude, like model and brand, on some Gigabyte cards you have to tight screws in order to put back cooler when replace, happened with my older Windforce 3X GTX 760, when repasted had to tight the cooler with the 4 screws making a "X" patern, starting with a corner, going straig the front screw and leaving it tight as possible, taking care not to bend or break parts, scratch PCB or so, be sure that thermalpads are in their place, cuz if moved might block cooler and add a gap for the cooler.
But again, a picture will be pretty useful here, to help you.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
If you feel like the spacing/sizing tolerance of the screws isnt proper, than simply contact gigabyte, let them know and they should send you out replacement screws ,or at worst give you an RMA. In all my years I've never encountered something like this that wasn't due to a human error mistake, but if you genuinely think there's improperly sized mounting hardware ,then I'd recommend you get the proper hardware rather than grinding screws, etc, because any permanent modification you do is going to void your warranty
