Hello Guys!! Need your help to BUILD MY PC WITH GPU 6800 AMD PULSE !! NEW BUILD HELP!!
84 (0.10/day)
System Name RedC0DE
Processor AMD 9 5950X
Motherboard B550 ASUS ROG STRIX GAMING WIFI II
Cooling DEEPCOOL LS720
Memory 32GB DDR4
Video Card(s) AMD RX 6800
Storage 1 TB NVME M.2 SSD
Display(s) AW2720HF - AW2720HFA
Case NZXT H7 ELITE
Power Supply Asus Rog Strix 1000W
Mouse Razer Basilisk V2 Hypershift
Keyboard AlienWare 410K
Software Windows 11 HOME
So, hello people one more time im back again here lol, but this time i am back with a bit of help for a build. Last time I asked about a gpu here most of the people suggested me to go with amd 6800 for my budget that i've had, and i had a shitty cpu i7 8700 which bottlenecks because of my board which is shit so i decided to do an upgrade of the whole thing and i need your help guys one more time, I hope it's not a problem!
So, my suggestion as i've read I think the cpu - AMD RYZEN 9 5900X will pair great with my gpu 6800 and its best as a workstation for my case ( I do a lot of editing videos, rendering, also a bit of gaming, prob will stream as well, multitasking, so i decided to go with this cpu which seems the best for me), but now i have another problem, so in my country i only could find two board (motherboards) which would go great with that cpu but idk which one to decide -so the first motherboard that i've seen it's
ASUS TUF GAMING X570-PRO (WI-FI) - AMD X570 , II - which costs round 259 Euros - - - but unfortunately this board is used - and has a warranty only for 3 months and the other board was
ASUS ROG Crosshair VIII IMpact - Amd X570 - DTX - Which is New and costs only 286 Euros.
Now I am in dilema and don't know which one to pick, I would go with the Asus Rog Crosshair VIII Impact but it's small and on a big case like nzxt h5 flow won't look great they told me ( I don't care how does it look as long as it works fine)
So my question is:
Which Motherboard of one of these would you suggest me to get?
and after you answer the question of motherboard - with what case should it go best?
and after that I need a suggestion for cpu cooler for that one, that you will suggest!
I hope I didn't Bother -
I already got the Ram memory sticks and the PSU which is 750Watt Gold which is fine I think - could handle AMD 9 5900X and my GPU 6800!
So my only concern as for now is the - motherboard - the Case and The CPUCOOLER FOR AMD 5 5900X.
Hope I'll get some help!
If you're looking at used boards I just picked up a used ASUS X570 for $100 shipped on eBay. Don't know if they'd be as cheap for you, but it's worth looking in to.
Just about any X570 board should be fine. If you have space for an ATX board I'd go that way vs ITX or mATX. Ideally with at least two m.2 slots. Gives you more options for expansion.
The Crosshair is easily the better option between the two you listed on build quality.
However, as you mentioned, you'll use it as a workstation. Would the CH8 Impact handle your storage needs?
The new Crosshair is a way better value than the used tuf.
Is there not any X570S boards in your price range?
If you go with the impact a good case would be the lian li 011 air the upside is it works with all standard motherboard sizes has decent air cooler clearance.
@freeagent would be a good person to recommend a cooler he has a 5900X he runs ballz to the wallz
I won't need more space than one m2 - 1tb nvme and an samsung sata 1tb so in total 2 tb would be fine for me - idk if this board would support that, because im kinda a newbie about this that's why i asked here!
Is this the one ur talking bout? I found this on the website which i will order the other stuff! I am just concerned about the airflow and I hope it won't like get gpu hot temps? Because I spoke to a pc builder guy and he told me that it might be the issue the airflow if i use the dtx board?
I play games as well, stream, multitasking so that won't be issue?
If you're gonna use 1 NVMe and 1 SATA drive the Crosshair will handle them with no issues, regardless of how large those drives may be.
Also currently I own a mid - tower -
Metallicgear Neo Silent -​
Will it be okay to put the dtx inside of this case? I don't really care how it looks like because I don't want to my pc to look cool tbh as long as it will do the job good that's totally fine with me!
and an
Arctic Freezer 34 CO​
Idk if it's good idea to put this cooler in the AMD 9 5900X please let me know about this as well guys!
and an
If you already have it might as well use it.
Stock that cooler will be fine.
Edit. Thought that was a different cooler unlikely that will handle the 130-140w the 5900X does stock.
I mean, he can use it as a starting ground and then upgrade as soon as able to. If anything, tuning PBO (can't recall if Ryzen 5000 has Eco mode) helps as well.
I can buy a new cooler, like an AIO one
I've heard good things about the Dark Rock pro 4 and the Deepcool AK620 is also solid.
If you want somthing cheaper the Thermalright Peerless Assassin is also solid.
I think I might go with NZXT Kraken X53 what do you think?
Solid cooler, I would say most 240mm aio are gonna perform about the same so as long as it comes with a 5/6 year warranty you should be golden
I have had really good luck with Enermax Liqmax 360. I got it for $74.99 and I haven’t seen higher than 48C on my 12600KF
Their issues with coolers being clogged because they either used poor quality growth inhibitors or didn't flush them out appropriately would make me nervous otherwise they seem like really solid coolers.
To be fair they did seem to handle it well with proper replacements but still.
Thermalright AIOs are dirt cheap and very capable.
Either is fine. Just get the cheaper board as both will work fine.
Guys I have one more question!
What's the difference between -
Procesor AMD Ryzen 9 5900X (100-100000061WOF)​
and
AMD Ryzen 9 5900X​
is there any difference? because i don't really get it - the (100-100000061) WOF is cheaper but I don't understand what might be the difference?
and
AMD Ryzen 9 5900X​
Both from the same reseller? It may be the cheaper one doesn't come with its box, but without seeing it's just conjecture from my part.
