Processor | 3900x - Bykski waterblock |
Motherboard | MSI b450m mortar max BIOS Date 27 Apr 2023 |
Cooling | αcool 560 rad - 2xPhanteks F140XP |
Memory | Micron 32gb 3200mhz ddr4 |
Video Card(s) | Colorful 3090 ADOC active backplate cooling |
Storage | WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb |
Display(s) | 24“ HUION pro 4k 10bit |
Case | aluminium extrusions copper panels, 60 deliveries for every piece down to screws |
Audio Device(s) | sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh |
Power Supply | Corsair RM1000x |
Mouse | pen display, no mouse no click |
Keyboard | Microsoft aio media embedded touchpad (moded lithium battery 1000mAh) |
Software | Win 11 23h2 build 22631 |
Benchmark Scores | cine23 20000 |
NopeHi,
So I want to upgrade my specs. Preferably only the GPU.
The one I have is a RTX 2080. And i would love to get a RTX 3090 TI or RTX 4090. Is it enough with a 750W PSU for either of them?
Thanks for you reply.Nope
850 is required as on Nvidia spec sheet:
System Name | Gamer |
Processor | Ryzen 7 5800X3D |
Motherboard | Gigabyte X570 Aorus Elite WIFI |
Cooling | Apogee XL, MCR360, MCP655, Micro-rez |
Memory | 2x16GB G.Skill DDR4-3600 CL16 |
Video Card(s) | RX 9070 XT Hellstone OC |
Storage | WD SN850 1TB & SN750 1TB |
Display(s) | LG 32GK650F-B 32" 1440p 144Hz |
Case | Rocketfish (Lian Li) e-ATX (2006) |
Audio Device(s) | Harman Kardon HK695 2.1 |
Power Supply | Seasonic Focus GX-850 |
Mouse | HP HDX wired |
Keyboard | Logitech G110 wired |
VR HMD | HP WMR 1440^2 |
Software | Win10 Pro 64bit |
System Name | I don't name my systems. |
Processor | i5-12600KF 'stock power limit and clock/-115mV undervolt+contact frame' |
Motherboard | Asus Prime B660-PLUS D4 |
Cooling | ID-Cooling SE 224 XT ARGB V3 'CPU', 4x Be Quiet! Light Wings + 2x Arctic P12 black case fans. |
Memory | 4x8GB G.SKILL Ripjaws V DDR4 3200MHz |
Video Card(s) | Asus TuF V2 RTX 3060 Ti @1920 MHz Core/@950mV Undervolt |
Storage | 4 TB WD Red, 1 TB Silicon Power A55 Sata, 1 TB Kingston A2000 NVMe, 256 GB Adata Spectrix s40g NVMe |
Display(s) | Dahua 30" LM30-E330CA 2560x1080 21:9 R1500 Curve/VA/200Hz Adaptive Sync |
Case | Be Quiet! Pure Base 500 FX Black |
Audio Device(s) | Onboard + Hama uRage SoundZ 900+USB DAC |
Power Supply | Seasonic CORE GM 500W 80+ Gold |
Mouse | Canyon Puncher GM-11 |
Keyboard | SPC Gear GK630K Tournament 'Kailh Brown' |
Software | Windows 10 Pro |
Nope
Thank you for your reply.Thats not necessarily true.
I have a friend whos using a RTX 3090 Strix with a 750W PSU + 9900K on water and hes fine.Not sure if he has any OC on his parts but stock does work and hes been using it like that since 2021 december.
Personally I have a RTX 3060 Ti with a 500W PSU and it works with no issues whatsoever, even tho Nvidia says 600-650W minimum.
This ofc also depends on the rest of the system, oced or not,etc.
You can undervolt and blah blah. But I don't see why someone spending 1600$ would not upgrade his psu.Thanks for you reply.
I am not that good with the component and building part of it.
When I tried to put it here: https://pcpartpicker.com/list/b7ybcb
It does say that usage is not even 700W, that is why I am mainly asking.
And what card would u buy? Is it Ventus/eagle or Evga FTW3 Rog Suprim X
Besides if you use the minimum psu wattage, your psu is going to get hot and noisy. Better get a 1000w so that you enjoy the zero-fan mode.
GPUs sometimes spike to much higher voltages that can turn your PC off. While it is 450w on paper, it can jump to 563w for 20 milliseconds
EVGA GeForce RTX 3090 Ti FTW3 Ultra Review
The EVGA GeForce RTX 3090 Ti offers a lot of customization options thanks to its triple BIOS that lets you pick between Normal, OC, and Performance. The massive quad-slot cooler keeps the card at good thermal levels, and the backplate is one of the best we've ever encountered.www.techpowerup.com
Product Specifications
Specifications
- GPU
GeForce RTX 3090 Ti- CUDA cores
10752- Video Memory
24GB GDDR6X- Memory Bus
384-bit- Engine Clock
Boost: 1890 MHz- Memory Clock
21 Gbps- PCI Express
4.0 16x- Display Outputs
3 x DisplayPort 1.4a (up to 7680x4320@60Hz)
1 x HDMI® Connector*
*Supports 4K 120Hz HDR, 8K 60Hz HDR, and Variable Refresh Rate as specified in the HDMI 2.1 Specification- HDCP Support
2.3- Multi Display Capability
Quad Display- Recommended Power Supply
850W- Power Consumption
450W- Power Input
PCI-e 5.0 12+4-pin (12-pin compatible)- DirectX
12 Ultimate- OpenGL
4.6- Cooling
IceStorm 2.0- Slot Size
3.5 slot- SLI
NVLink Ready- Supported OS
Windows 11 / 10 (64-bit, April 2018 update or later)- Card Length
355.9mm x 149.7mm x 63.9mm / 14" x 5.89" x 2.52"- Accessories
ZOTAC GAMING RGB GPU Support Bracket
3-pin RGB Header Cable
3 x 8-pin to 12-pin cable
Manual
Uh-huh, 679w I see. But PSUs are not 100% efficientIt does say that usage is not even 700W, that is why I am mainly asking.
Agreed, every PSU has a efficiency/power load curve, and generally you need to be about 40% - 60% above the wattage to hit the sweet spot.You can undervolt and blah blah. But I don't see why someone spending 1600$ would not upgrade his psu.
System Name | Upgraded CyberpowerPC Ultra 5 Elite Gaming PC |
Processor | AMD Ryzen 7 5800X3D |
Motherboard | MSI B450M Pro-VDH Plus |
Cooling | Thermalright Peerless Assassin 120 SE |
Memory | CM4X8GD3000C16K4D (OC to CL14) |
Video Card(s) | XFX Speedster MERC RX 7800 XT |
Storage | TCSunbow X3 1TB, ADATA SU630 240GB, Seagate BarraCuda ST2000DM008 2TB |
Display(s) | AOC Agon AG241QX 1440p 144Hz |
Case | Cooler Master MasterBox MB520 (CyberpowerPC variant) |
Power Supply | 600W Cooler Master |
I think that's only if you have an AIB partner model with a heavy overclock (e.g. one of the rumoured 600W+ models), if you intend to overclock the GPU heavily yourself, or if you have a cheap or badly-designed PSU which can't handle transient power spikes properly without exploding (like a Gigabyte P850GM). The base model/founders-edition RTX 4090 only requires an 850W PSU.The RTX 4090 will need a 1000w or possibly more from what I have read.
If you don't want to replace your PSU, you'd be much better-off with an RTX 4080 16GB (which is significantly faster than the RTX 3090 Ti, uses less power, and should be about the same price) or waiting a couple of months to see what AMD has to offer. "a RTX 3090 TI or RTX 4090" seems to me like an odd choice - there's a huge gap in performance between them, which the RTX 4080 16GB should fit into the middle of, with better efficiency and value. I guess an RTX 3090 Ti could make sense for workstation tasks that require a lot of VRAM, but if that's your main priority, you may as well get an RTX 3090 non-Ti or (if your workload doesn't require CUDA and can scale across 2 GPUs) two RX 6800s.
Processor | Intel i7 4770k |
Motherboard | ASUS Sabertooth Z87 |
Cooling | BeQuiet! Shadow Rock 3 |
Memory | Patriot Viper 3 RedD 16 GB @ 1866 MHz |
Video Card(s) | XFX RX 480 GTR 8GB |
Storage | 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB |
Display(s) | AOC Q27G2U QHD, Dell S2415H FHD |
Case | Cooler Master HAF XM |
Audio Device(s) | Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251 |
Power Supply | Corsair AX860 |
Mouse | Razer DeathAdder V2 |
Keyboard | Razer Huntsman Tournament Edition |
Software | Windows 10 Pro x64 |
