Never mind the title then.
Try installing and running a program called
HijackThis. Just run it in administrator mode, do a scan and save a logfile, and after paste that logfile into
this site's textbox. Press analyze and check if there's anything wrong. If you have any doubts, please, post them here.
The ESET Smart Security is an A-OK AV, in my opinion, as I also use it. There's just one problem with it, without real-time protection over all things, rootkits get in very easily (as well as with any other AV with real-time disabled) and are (almost) never spotted after they're in.
Winpatrol is a very good tool, but only if you know what you are looking for.
And if Malware bytes didn't find a rootkit, either it's very well buried (and in that case, any other anti-rootkit won't find it) or it isn't there at all.
You said you didn't find practically anything about you're problem. I did some research, as this is a rather odd thing, and found out that this, in case of not being a rootkit, it's most likely a corrupt registry.
Backup your files, boot into safe mode, and run for a last time all of your security systems, as an administrator and enable low-lever searches if that's available. Low-lever searches are needed because the rootkit (if there is one) can be running with a kernel driver and in safe mode it will be disabled (hopefully
If it was a rootkit and you solved it, your problems should be gone, if not, there are more drastic measures:
1 - Repair Install
Then login to your computer, take your Win7 DVD, and with it try to do a repair it with the repair install option. This may correct any problems with the Windows registry. Beware some applications and drivers may need to be reinstalled after this.
Heres a neat Guide on how to do it.
2 - Format and Reinstall Windows
This one is pretty much known by everyone that uses a computer and already has had a serious problem with it. It's the harshest approach, but most of the times, the most effective.
Due to the lack of info on that particular problem, there aren't any more options I can give you (for the time being...), as it is a very awkward problem.
P.S.: If anyone else wants to give any more inputs to help, I think they would be very welcome.
Please help. I am having the same issue. Thank you.
Logfile of Trend Micro HijackThis v2.0.5
Scan saved at 1:08:51 PM, on 9/14/2018
Platform: Windows 7 (WinNT 6.00.3504)
MSIE: Internet Explorer v8.00 (8.00.7600.16385)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\Hewlett-Packard\HP ProtectTools Security Manager\Bin\DPAgent.exe
C:\Users\ugyen sir\AppData\Roaming\EpicNet Inc\CloudNet\cloudnet.exe
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe
C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
C:\Program Files (x86)\HP\StatusAlerts\bin\HPStatusAlerts.exe
C:\Program Files (x86)\SAP\SapSetup\setup\Updater\NwSapSetupUserNotificationTool.exe
C:\Program Files (x86)\Common Files\Portrait Displays\Drivers\SDKCOMServer.exe
C:\Users\ugyen sir\Downloads\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page =
http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page =
http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL =
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL =
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
F2 - REG:system.ini: UserInit=userinit.exe
O1 - Hosts: 0.0.0.1 mssplus.mcafee.com
O2 - BHO: BHO_Startup - {3134413B-49B4-425C-98A5-893C1F195601} - C:\Program Files (x86)\Hewlett-Packard\File Sanitizer\IEBHO.dll
O2 - BHO: Lync Click to Call BHO - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O2 - BHO: IESpeakDoc - {8D10F6C4-0E01-4BD4-8601-11AC1FDF8126} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~2\MICROS~1\Office15\URLREDIR.DLL
O2 - BHO: Soda PDF 5 IE Helper - {C737F472-1193-4281-BF53-A00B67AB3E19} - C:\Program Files (x86)\Soda PDF 5\PDFIEHelper.dll
O2 - BHO: Microsoft SkyDrive Pro Browser Helper - {D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF} - C:\PROGRA~2\MICROS~1\Office15\GROOVEEX.DLL
O3 - Toolbar: Soda PDF 5 IE Toolbar - {F335ABA2-FDB4-4644-92B2-5CC4B0FC91D6} - C:\Program Files (x86)\Soda PDF 5\PDFIEPlugin.dll
O4 - HKLM\..\Run: [QLBController] C:\Program Files (x86)\Hewlett-Packard\HP HotKey Support\QLBController.exe /start
O4 - HKLM\..\Run: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
O4 - HKLM\..\Run: [NUSB3MON] "C:\Program Files (x86)\Renesas Electronics\USB 3.0 Host Controller Driver\Application\nusb3mon.exe"
O4 - HKLM\..\Run: [DTRun] C:\Program Files (x86)\ArcSoft\TotalMedia Suite\TotalMedia Theatre 3\uDTRun.exe
O4 - HKLM\..\Run: [HPConnectionManager] C:\Program Files (x86)\Hewlett-Packard\HP Connection Manager\HPCMDelayStart.exe
O4 - HKLM\..\Run: [PDF Complete] C:\Program Files (x86)\PDF Complete\pdfsty.exe
O4 - HKLM\..\Run: [File Sanitizer] C:\Program Files (x86)\Hewlett-Packard\File Sanitizer\CoreShredder.exe
O4 - HKLM\..\Run: [HP Software Update] C:\Program Files (x86)\Hp\HP Software Update\HPWuSchd2.exe
O4 - HKLM\..\Run: [StatusAlerts] "C:\Program Files (x86)\HP\StatusAlerts\bin\HPStatusAlerts.exe" /enum
n /alerts
n /notifications
n /fl
n /fr
n /appData
n /tmcp
n
O4 - HKLM\..\Run: [SAP_WUS_UNT] "C:\Program Files (x86)\SAP\SAPsetup\setup\Updater\NwSapSetupUserNotificationTool.exe"
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKCU\..\Run: [McAfeeSafeConnect] C:\Program Files (x86)\McAfee Safe Connect\McAfee Safe Connect.exe
O4 - HKCU\..\Run: [WildMeadow] "C:\Windows\rss\csrss.exe"
O4 - HKCU\..\Run: [CloudNet] "C:\Users\ugyen sir\AppData\Roaming\EpicNet Inc\CloudNet\cloudnet.exe" 31339
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - Global Startup: McAfee Security Scan Plus.lnk = C:\Program Files\McAfee Security Scan\3.11.766\SSScheduler.exe
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office15\EXCEL.EXE/3000
O8 - Extra context menu item: Se&nd to OneNote - res://C:\PROGRA~1\MICROS~2\Office15\ONBttnIE.dll/105
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: Se&nd to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIE.dll
O9 - Extra button: Lync Click to Call - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra 'Tools' menuitem: Lync Click to Call - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files (x86)\Microsoft Office\Office15\OCHelper.dll
O9 - Extra button: (no name) - {7815BE26-237D-41A8-A98F-F7BD75F71086} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O9 - Extra 'Tools' menuitem: Send by Bluetooth to - {7815BE26-237D-41A8-A98F-F7BD75F71086} - C:\Program Files (x86)\Bluetooth Suite\IEPlugIn.dll
O9 - Extra button: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIELinkedNotes.dll
O9 - Extra 'Tools' menuitem: OneNote Lin&ked Notes - {789FE86F-6FC4-46A1-9849-EDE0DB0C95CA} - C:\Program Files (x86)\Microsoft Office\Office15\ONBttnIELinkedNotes.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{F5A50334-1C8A-4C73-9E66-432909EAD553}: NameServer = 202.144.128.214,202.144.128.205
O18 - Protocol: osf - {D924BDC6-C83A-4BD5-90D0-095128A113D1} - C:\Program Files (x86)\Microsoft Office\Office15\MSOSB.DLL
O18 - Filter hijack: text/xml - {807583E5-5146-11D5-A672-00B0D022E945} - C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\MSOXMLMF.DLL
O20 - Winlogon Notify: DeviceNP - DeviceNP.dll (file missing)
O23 - Service: SAS Core Service (!SASCORE) - SUPERAntiSpyware.com - C:\Program Files\SUPERAntiSpyware\SASCORE64.EXE
O23 - Service: ArcSoft Connect Daemon (ACDaemon) - ArcSoft Inc. - C:\Program Files (x86)\Common Files\ArcSoft\Connection Service\Bin\ACService.exe
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) - Adobe Systems Incorporated - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: Andrea ST Filters Service (AESTFilters) - Unknown owner - C:\Program Files\IDT\WDM\AESTSr64.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Atheros Bt&Wlan Coex Agent - Atheros - C:\Program Files (x86)\Bluetooth Suite\Ath_CoexAgent.exe
O23 - Service: AtherosSvc - Atheros Commnucations - C:\Program Files (x86)\Bluetooth Suite\adminservice.exe
O23 - Service: Intel(R) Content Protection HECI Service (cphs) - Intel Corporation - C:\Windows\SysWow64\IntelCpHeciSvc.exe
O23 - Service: @C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\Bin\DpHostW.exe,-128 (DpHost) - DigitalPersona, Inc. - C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\Bin\DpHostW.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: HP ProtectTools Device Locking / Auditing (FLCDLOCK) - Hewlett-Packard Company - C:\Windows\SysWOW64\flcdlock.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Unknown owner - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (file missing)
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Unknown owner - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (file missing)
O23 - Service: HP LaserJet Service - Unknown owner - C:\Program Files (x86)\HP\HPLaserJetService\HPLaserJetService.exe (file missing)
O23 - Service: HP Power Assistant Service - Hewlett-Packard Company - C:\Program Files\Hewlett-Packard\HP Power Assistant\HPPA_Service.exe
O23 - Service: HP ProtectTools Service - Hewlett-Packard Development Company, L.P - C:\Program Files (x86)\Hewlett-Packard\2009 Password Filter for HP ProtectTools\PTChangeFilterService.exe
O23 - Service: HP Connection Manager 4 Service (hpCMSrv) - Hewlett-Packard Development Company L.P. - C:\Program Files (x86)\Hewlett-Packard\HP Connection Manager\hpCMSrv.exe
O23 - Service: HP Quick Synchronization Service (HPDrvMntSvc.exe) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\HPDrvMntSvc.exe
O23 - Service: File Sanitizer for HP ProtectTools (HPFSService) - Unknown owner - C:\Program Files (x86)\Hewlett-Packard\File Sanitizer\HPFSService.exe (file missing)
O23 - Service: hpHotkeyMonitor - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\HP Hotkey Support\HpHotkeyMonitor.exe
O23 - Service: HP Software Framework Service (hpqwmiex) - Hewlett-Packard Company - C:\Program Files (x86)\Hewlett-Packard\Shared\hpqWmiEx.exe
O23 - Service: HP Service (hpsrv) - Unknown owner - C:\Windows\system32\Hpservice.exe (file missing)
O23 - Service: Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
O23 - Service: Intel(R) Identity Protection Technology Host Interface Service (jhi_service) - Intel Corporation - C:\Program Files (x86)\Intel\Services\IPT\jhi_service.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: McAfee Endpoint Encryption Agent - Unknown owner - C:\Program Files\Hewlett-Packard\Drive Encryption\EEAgent\MfeEpeHost.exe (file missing)
O23 - Service: McAfee Security Scan Component Host Service (McComponentHostService) - McAfee, Inc. - C:\Program Files\McAfee Security Scan\3.11.766\McCHSvc.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: SAPSetup Automatic Workstation Update Service (NWSAPAutoWorkstationUpdateSvc) - SAP AG - C:\Program Files (x86)\SAP\SAPsetup\setup\Updater\NwSapAutoWorkstationUpdateService.exe
O23 - Service: PDF Document Manager (pdfcDispatcher) - PDF Complete Inc - C:\Program Files (x86)\PDF Complete\pdfsvc.exe
O23 - Service: Portrait Displays SDK Service (PdiService) - Portrait Displays, Inc. - C:\Program Files (x86)\Common Files\Portrait Displays\Drivers\pdisrvc.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: QMEmulatorService - Tencent - C:\Program Files\TxGameAssistant\AppMarket\QMEmulatorService.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: RtlISMServ - Unknown owner - C:\Program Files (x86)\Hewlett-Packard\HP Internet Sharing Manager\HP_UI\RtlService.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: Soda PDF 5 Helper Service - LULU Software - C:\Program Files (x86)\Soda PDF 5\HelperService.exe
O23 - Service: Soda PDF 5 Service - LULU Software - C:\Program Files (x86)\Soda PDF 5\ConversionService.exe
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\stlang64.dll,-10101 (STacSV) - Unknown owner - C:\Program Files\IDT\WDM\STacSV64.exe (file missing)
O23 - Service: TCPSvc - Unknown owner - C:\Users\ugyen sir\AppData\Local\Temp\csrss\proxy\tor.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: Intel(R) Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Validity VCS Fingerprint Service (vcsFPService) - Validity Sensors, Inc. - C:\Windows\system32\vcsFPService.exe
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: Windows Defender Helper Service (Windows 1703 Creators Update) (WinDefender) - Unknown owner - C:\Windows\windefender.exe
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 15023 bytes
