Help! Beats By Dre Studio Help!
rhong
4 (0.00/day)
Hi! I need help with the Beats By Dre Studios, On the right ear pad with the pause button i pushed it too hard so know its loose in side the ear pad, would like to get some help how to fix it.
Should i disassemble it and if i should how? would really love to get help!
Thank you!
Make sure opening up the the unit will not void the products warranty if it still has one.
Get a screw driver and look for screws inside the earpiece which has the affected.
There maybe be areas which required popping off possibly hinged with plastic.
RMA and let them fix it. No reason to void your warranty only to find you can't fix it.
