help burning vist to dvd
newmodder
669 (0.09/day)
british columbia
System Name Gamer
Processor amd phenom quad core 9950 black edition
Motherboard msi ms-7309
Cooling 120mm front,120mm rear
Memory 2gigs ddr2 800
Video Card(s) BFG gtx 260 maxcore
Storage wd 160gig sata2 hd
Display(s) LG 20in widescreen
Case USP 100
Audio Device(s) onboard Logitech x-530 5.1 spkrs
Power Supply Antec Neo 550watt
Software windows 7 Ultimate 64 bit
ok i ahve it dowloaded, and have a dvd burner, blank dvd...now do i just burn it as a DATA, BOOTABLE DVD or what..i am stuck and dont want f@*@! this up since i just bouhgt a single blank dvd.
I would/will be useing Alcohol 120% to burn the iso file to a disk. You can dl your 30 day trial here: http://www.alcohol-soft.com/
Start up Alcohol 120%, click the "Image Burning Wizzard", browse for your dl'ed Vista iso file and burn.
found it
i found my dvd install cd, it has Nero on it..i just used that...burnt it as a dvd image.Today i went out and bouhgt 160gig sata hd.i booted from dvd and went to install on my new hardrive and Vista install said i only had 10gigs of space on it...whasss up with that? i installed my raid drivers and stuff, formatted the drive to NTFS.what else can i do?
Can i just detatch my old ide with xp on it and install Vista on the sata. then hook up the ide after and still have both operating systems?
