Help! Computer keep shutting down problem
EladS
4 (0.00/day)
I bought new antec case for my computer. I just moved everything to it. Not touched anything. But now the computer keep shutting down. I tried new power supply and other memory but still happening. Can be 5 second. can be 30 minutes but always happening.
Mobo: Gigabyte Z270 HD3P
CPU: I7 7700
PSU: Antec 550w
Memory: G.skill ripjaw 2400
Graphic card: Sapphire RX 570
7,412 (2.63/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
4,543 (0.80/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
How did you move the parts without touching them ;). Check your wires. If that doesn’t work then test outside the box on some cardboard
EladS
4 (0.00/day)
I did reinstall the motherboard still always shut down
Regeneration
NGOHQ.COM
3,151 (0.44/day)
Loosen the motherboard screws. Try to plug one thing at a time. Try another power cable.
Check for any damage on the motherboard circuits, or for something loose that may shorten the system.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
I'd double check the power cables - that they're properly inserted, both on the motherboard and the PSU if it's modular . Also, did you happen to unplug the CPU fan?
1,843 (0.59/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
Also check if your motherboard maybe touching the case from the back side and making some potential unwanted contact with the metal that can produce short circuit.....you can put some cardboard in between to be sure it's separated .....
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Ah, no. Under the right conditions, cardboard could cause a short. Air gap with the standoffs is the best.
EladS
4 (0.00/day)
I released screws and connected fans to power supply instead of motherboard. 1 hour with no shut down.
1,843 (0.59/day)
BGD
Case NZXT H5 Flow
Software Win 11
Well...it helped me once but yeah it's not ideal solution.....
EladS
4 (0.00/day)
Shut down after 10 hours :mad::banghead:
Now I reinstall everything and put cardboard behind Mobo.
