Help for my GPU
miner.brasil.bes
7 (0.01/day)
I'm looking for the bios for my card, if anyone can help me I'd appreciate it, and an RX 580 8 GB, but from the posts I saw it could be a 470 or 570.
I'm guessing 570. The 470D that came in a similar config was limited to 4GB VRAM.
Is it working correctly?
Also I suggest posting in English; it makes it easier on the rest of us that are not from your area.
Good morning friend, I have two cards and neither of them is giving video, I was using it in mining and I want to go back to the original bios, this card was bought on Aliexpress, in mining it is good but it is not giving video, and I don't know which bios to use and I didn't find a specific bios for this memory.
Bom dia amigo, eu tenho dois cartões e nenhum deles está dando vídeo, eu estava usando na mineração e eu quero voltar para as bios originais, este cartão foi comprado no Aliexpress, na mineração é bom mas não está dando vídeo, e eu não sei qual bios usar e eu não encontrei uma bios específica para esta memória.
English if you can please
I know this is an incredibly long list but one of them will do.
Hang on, you have multiple memory types on that list. Also, this die appears to be an RX 470 die, used primarily on mining GPUs.
@miner.brasil.bes can you get a picture of any stickers on the card, as well as an overall shot of the PCB? This will help us find the right version of the BIOS for you.
This one seems like it might be worth a shot. However I do not know for sure if it will work.
More AI Photo
Amanhã eu vou tentar
When I search on the board name/number "160430HJB" it seems to be based on a XFX RX470 board
Can you try this RX470 bios:
Some RX580 2048SP bios which might work as well.
Good morning, look how strange I have two card here rx580 bought with the same seller, this one I posted and the other I got the bios, because the other is hynix memory, when I run hiveos the two cards it presents the same SK hynix memory H5GC8H24MJR. but on the secudanria plate in memory it has the ending XXXXAJR, and on the hiveos xxxxMJR at the end.
I see I accidently put the wrong bios in my previous message by mistake. I did strike-through.
160430HJB with Micron
160430HJB with Hynix (AJR)
Vejo que acidentalmente coloquei a bios errada na minha mensagem anterior por engano. Fiz strike-through.
160430HJB com mícron
160430HJB com Hynix (AJR)
@VuurVOS How do you know what name of this memory and it's Samsung-Hynix-Micron etc...
@VuurVOS I tested this one worked by the cmd command, do the test to see........Coleção VGA Bios: AMD/ATI RX 580 2048SP 8 GB | TechPowerUp
@VuurVOS so I understood, but I couldn't find the model of the micron type chip AND WITH THIS NUMBERING 8EA45D9SXD
Only the last part of the numbering is interesting which is a FBGA code (D9SXD).
You can use it to lookup the Micron part number.
In your case the part number is MT51J256M32HF-70:A. The Micron board bioses which are provided earlier have support for this memory.
