!Help!, I've got bsod during my first folding at home try
202 (0.04/day)
lol
System Name BrighTaloN
Processor 980X
Motherboard DX58SO2
Cooling Corsair H100 dual cougar 12cm pwm fans
Memory CMZ16GX3M4X1600C9G
Case Haf X
Power Supply Toughpower Grand 750
Software 7 Proff 64-bit
Benchmark Scores never did atm
http://i329.photobucket.com/albums/l399/Croszius/remus.jpg
http://i329.photobucket.com/albums/l399/Croszius/IMG-20120417-00025.jpg
Windows error report description:
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional information about the problem:
BCCode: 124
BCP1: 0000000000000000
BCP2: FFFFFA80095DF028
BCP3: 00000000BA000000
BCP4: 0000000000400405
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\041712-27658-01.dmp
C:\Users\†\AppData\Local\Temp\WER-59701-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
What's wrong with my machine? please somebody help me address this issue :\
ps: my cpu was once ocd to 5.9ghz 1.7v(about 2 years ago)
It's running at stock all the time, Which cowbell did you mean lol
Moved to F@H
124 stop error mostly means lack of Vcore. it can also mean lack of VTT.
Is the error message mostly accurate? I don't even oc my cpu :\
Maybe it's just punishing it more when folding and if your CPU VTT is on "auto" it's not giving it quite enough, check what auto is defaulting VTT to and raise it a couple of increments in the Bios.
Yes it was the first BSOD I've got after about 1.5 years of use oh and what's VTT? what does it stand for? my motherboard is DX58SO2, does that term apply to any motherboard?
Have a read here on VTT and other terminology..........
http://www.masterslair.com/vcore-vtt-dram-pll-pch-voltages-explained-core-i7-i5-i3/
On your boards Bios, you should be able to find it under Config >>> Performance, if still unsure look at page 30 of your bios user guide here......
http://download.intel.com/support/motherboards/desktop/sb/biosglossarybymenu_v17.pdf
Thank you for your great care, I love that
here are some photos of my BIOS config:
As we can see above, the cpu is untouched.
I adjusted the RAM's specs to the advertised specs
http://www.mushkin.com/Memory/Blackline/998681.aspx
But I also adjusted the uncore speed without bumping the uncore voltage(because some people told me that I don't need to)
anything seem wrong?
First, welcome to Folding. Sorry about the bumps.
The GTX 580 puts quite the load on the CPU. Try reducing the number of cores used for SMP by 1 or 2. Total output will actually increase.
Thank you mate and nothing's wrong at all about bumping this thread up I guess.
Apparently the prob was with my uncore/qpi voltage, I bumped it up a bit, increased the processor multiplier by 1, ran prime95 blend for 12 hours and voila no blue screen.
I'm doing my best not to reduce anything but voltage lol
